Battery Warning Light - HELP!!!
Old 02-17-15, 02:31 PM
GiantsFan
GiantsFan's Avatar
Sounds like the alternator man...
Old 02-17-15, 02:52 PM
andy350
andy350's Avatar
Lexus tech guy just told me...it's the alternator...
alternator parts and labor $698
battery installed $200+
Taxes and other bs...$100
Total ... around $1,000
Old 02-17-15, 02:55 PM
jonathanz
jonathanz's Avatar
You don't need a new battery
Old 02-17-15, 03:24 PM
andy350
andy350's Avatar
they told me i need a new battery also...
on the bright side...they gave me 2015 rx350 loaner
my car will be ready tommorow
Old 02-17-15, 03:54 PM
Wht95scort
Wht95scort's Avatar
You don't need a battery. Tell them to replace the alt and re-charge the battery. It's just coming up bad as the life has been sucked out of it.
Old 02-17-15, 06:25 PM
jonathanz
jonathanz's Avatar
he's damn right, they measured the battery low cause it wasn't charged!
Old 02-17-15, 08:41 PM
Sffd103
Fire Slayer
Sffd103's Avatar
We told you it was the alternator. You could also have gotten an alternator from an auto parts store and had an independent mechanic for cheaper also. Just FYI.
Old 02-17-15, 09:15 PM
andy350
andy350's Avatar
only reason i went to Lexus dealership was because i thought i was going to get the battery pro-rated...which they denied...
i was going to buy new alternator from eBay for $200 and pay my local mechanic $200 to install...would have saved $300.
i always make stupid costly decisions and ask for advice but never listen...
i think i should see a doctor about this...what do u guys think...never mind, i'm probably not going to listen to your advice...
atleast i can admit i have a problem!!!
Old 02-18-15, 12:36 AM
GiantsFan
GiantsFan's Avatar
^Hey, admiting it is step 1!!!
Some solid advice given in this thread... Just gotta take it next time!
inlifex (10-31-17)
Old 10-31-17, 07:02 AM
inlifex
inlifex's Avatar
Great advise indeed, my 08 IS250 with 80K miles just did this to me, exact same symptoms and found this thread - got the alternator from AutoZone for 160 bucks and installed it myself (pain in the f'ng *** to get to the lower bracket nut). Now my battery light comes on when I hit high RPMs, need to check connections to make sure they're not lose, if they're all good anyone know if I need to reset codes or anything with the computer?
The interwebs says I could have bought a defective part (I guess it’s possible), especially if the part has been setting on a shelf for a long time.
Thanks!!!
Old 06-15-20, 08:42 PM
supralative
supralative's Avatar
OH man just did this
That one mount point below behind is not even needed
I ended up pulling the 12mm nut off and then the stud as well and did not put it back on
Pulled the ECU box out for room to pull the alternator out as well
All back in and seems good now
Old 07-03-21, 06:30 PM
CaptJustic
CaptJustic's Avatar
Thanks!!!
Hey I'm having the exact same issue. Except I bought new alternator and new battery. Even under load the battery is at a constant 14.4V. did you resolve this issue?
Nena250
03-07-19 01:12 PM
LeeRB
09-06-18 08:00 AM
amillion
01-20-13 04:56 PM
Sup2jzgte
SC- 1st Gen (1992-2000)
12
08-22-10 02:41 PM
2jz
GS - 1st Gen (1993-1997)
12-29-05 02:07 PM
Quick Reply: Battery Warning Light - HELP!!!
