[Need Expert Advice] Do these tires work on these wheels?
Old 01-29-15, 06:51 PM
reyoasian
reyoasian's Avatar
Default [Need Expert Advice] Do these tires work on these wheels?
Didn't get much attention from the Tire/Wheel section, so coming back to the 2IS for help..
I'm getting some G35 OEM Rays Forged wheels in this spec:
19x8 +30
19x8.5 +33
Since my 2009 IS250 is AWD, I should be running 225/35R19 front with 265//30R19 rear.
I know the front wont' have an issue with 225/35 on a 19x8.
What about the rear, is a 265/30 on a 19x8.5 too wide on the tires?
I'm thinking of running tires that aren't too "fat" such as the PSS, a buddy of mine ran 275/40R19 on a 19x9 and was perfectly flush with no stretch or the sidewalls bulging out (what other options are there?)
...I've also thought about running 235/35R19 all around but not sure if I'll like the look of the rear which will be slightly more stretch than the front.
Any advice?
Thanks
Old 01-30-15, 12:38 PM
Gville350
Gville350's Avatar
225/35/19 front with 265/30/19 rear will be fine. How low are you though?
Old 01-30-15, 01:23 PM
VIP Modular Wheels
VIP Modular Wheels's Avatar
since it is all wheel drive you'll be okay with the 265-30, the rolling diameter is the same as 225-35. if the tires are half way bad, I recommend you change all new 235-35 all around these won't stretch so they will all match !
reyoasian
Wheels, Tires & Brakes Forum
02-12-15 08:16 AM
FuMoFFuTT
SC- 1st Gen (1992-2000)
02-02-10 10:26 PM
slimjim
02-15-09 09:54 PM
skpark70
11-02-02 04:59 AM
Quick Reply: [Need Expert Advice] Do these tires work on these wheels?
