Scratched my car, need help
I scratched my car while backing out today. Fortunately, there's no dent and it doesn't seem to be a deep scratch. However, it's long and noticeable. I've heard about touch up paint from the dealer, how much would it cost and would it work well for this kind of scratch? My car is a 2009, is it possible that the paint color has faded and the touch up paint would not blend in? Thanks for helping.
+1 to buff it first. You won't get rid of it completely, but you will be able to hide some of it.
Then if it's still quite bad, use Dr. ColorChip. It's not very cheap, but it works much better than a paint pen.
Regardless though, scratches are harder to fix than rock chips. Good luck!
http://www.autogeekonline.net/forum/wet-sanding-cutting-buffing/51955-how-fix-deliberate-deep-key-scratch.html
check that link out. Of course your scratch is not as deep as this one, but just to get an idea
Scratches
Run your finer nail on the scratch surface to determine how deep the scratch was, if it did not penetrate through the paint, then you can begin to work on it. If the scratches penetrate through the paint, then you will need other method.
Clear Coat Scratches:
1) Use 2500 grids sand paper for light scratch and 2000 grids sand paper for deep scratch.
2) Wash the area with regular soap before wet sand to remove any dirt and wipe to dry with appropriate towel.
3) Start with 2500 sand paper if it was a light scratch, but not penetrate through the paint, and 2000 sand paper if it was a deep scratch. ALWAYS sand it WET. Use a regular spray bottle to fill with water and wet it really good while you sand the area. If you've never been done it before, start it out with 1 inch length of the scratch area to see the result. If you satisfy with the result, then you can finish the rest. In your case, use the 2500 grids sand paper just to be safe, it will take a bit longer to remove the scratch. Soak the 2500 grids sand paper with water and keep spraying onto the area you are sanding and keep it WET all the time. Use the up and down sanding motion on the scratch line with 1 inch to start out and sand it lightly for 5 to 10 times. Wipe the area dry with terry clothes after 10 times of sanding and inspect the scratch area by running your nail lightly to feel if you are still catching the scratch line area, if you do, then continue WET sanding until you don't catch any scratch line with your finger nail. BE CAREFUL NOT TO SAND THROUGH THE PAINT.
4) If you don't catch any scratch line with your finger nail, then wipe the area clean and let it dry 15 mins. You will need a clean buffing pad (2), dry terry cloth to wipe off any residue after buffing (2). You can use Meguiars Ultimate Compound or Ultra-Cut Compound for buffing after wet sanding was completed. Keep buffing until you don't see any cloudy area after you sanded. Once all the cloudy disappear, then use the Meguiars NXT Generation. Tech Wax 2.0 to bring back the shine. Use another clean buffing pad with the Tech Wax 2.0 to bring back the clear coat appearance. Keep your car in the garage and do not wash it for 2 weeks after you done all of these steps. Pls let me know if you have any other questions. These is how I did to remove scratches on the ISxx 2009 on door panel and hood as long as it did not penetrate through the paint. I never tried any touch up paint for Dr.color pen either. I chose this route because the results just like the professional would have done it. Good luck. Pls, keep us inform or the results.
zmcgovern4
Automotive Care & Detailing
42
12-26-14 12:51 PM
