RPM drop after letting off gas
This happens to my 250 as well. Usually occurs when tempurature is below freezing. Once you let go of the accelerator the RPM will dip for a second significant enough to cause a s light jerk in the car. But it isnt changing gears.. it does it even with the slightest tap to the accelerator. Usually disappears once engine reaches operating tempurature.
I was happy to find this thread and subscribed... Experiencing the exact same thing on my 2011 @ 50k miles, only until fully warmed up where it goes away. It's cold here, 15°F to -15°F, however outside temperature doesn't seem to impact as it's been ongoing for a long time. Although others are experiencing this, it never happened on my 2006 through 75k miles and I can't see that it would be normal... Still looking!
Any solution to this problem? My IS 250 has this problem when the temperature is low.
When I release the throttles, the rpms drops to ~ 0,9-1K and returns to the previous value after a second.
I heard that there is an air temperature sensor in the MAF sensor, but I have not tried to replace it yet. Maybe someone has information if I am right.
95gsDanG
GS - 1st Gen (1993-1997)
06-05-21 11:21 AM
1994 LS400
03-18-13 06:04 AM
Lexucan
15
09-15-07 02:14 PM
