Is there something wrong with this IS? (Carfax)
This IS seems to have gone in a lot for "Thrust angle alignment performed". Never seen a carfax with so many. Does that mean there is a problem with it's alignment?
http://www.carfax.com/VehicleHistory...&partner=VSR_0
Sure seems like maybe the previous owner was complaining about some sort of vibration. Looks like all the brake pads were replaced and the rotors were also resurfaced. Kinda strange to see that at less than 25k miles.
1 tire mounted and balanced at 10k miles seems a bit suspicious. The many alignments is definitely a red flag. It's possible that the previous owner may have hit a sidewalk or something.
For peace a mind, I would look for a different car.
Sorry to hijack this thread, but Im looking at a car that Im very serious about and found the following through Lexus service records. The car now has about 75k miles on it. How worried about this should I be?
Dealer Reported 08/12/2011 Mileage: 51314
FOUND BOTH FRONT & LEFT REAR TIRES AT <3/32 TREAD DEPTH. LEFT FRONT TIRE SEPARATING ON INNER SHOULDER - NOT SAFE TO DRIVE. RECOMMEND REPLACING TIRES & 4 WHEEL ALIGNMENT. ADVISED CUSTOMER.
Dealer Reported 08/25/2009 Mileage: 26721
STEERING WHL/MAIN SHAFT - VEHICLE NEEDS TIRE - MOUNT AND BALNCE PF TIRE
Dealer Reported 04/24/2009 Mileage: 23152
FRONT/REAR BODY - REPAIR AS PER SCOTT BIGGS - BUMPER AND GRILL ISSUES - COMPELTED - INSPECTED BY SCOTT BIGGS AFTER
STEERING WHL/MAIN SHAFT - RF TIRE HAS GOUGE MARK IN SIDEWALL - COSMETIC DAMAGE ONLY - CUSTOMER TO MONITOR - NOTE BILL BREWER AGREED TO REPALCE 1 TIRE IF NEEDED IN FUTURE
Dealer Reported 02/10/2009 Mileage: 21125
STEERING WHL/MAIN SHAFT - LF WHEEL DAMAGED - REPORT - TIRE RUINED ALSO - REPLACED LF WHEEL, TIRE AS NEEDED, VERIFIED ALIGNMETN SETTINGS ALSO
Dealer Reported 12/31/2008 Mileage: 19855
FRONT/REAR BODY - NEED ESTIMATE FOR LEFT REAR WHEEL OPENING DENT - ESTIMATE IS $375+TAX - TIME NEEDED IS 2 DAYS TO REPAIR
Dealer Reported 09/02/2008 Mileage: 14925
FRONT/REAR BODY - GET ESTMATE TO REPAIR REAR BUMPER - REPAIRED AND REFINISHED REAR BUMPER AS BEST AS POSSIBLE SLIGHT WAVE STILL THERE - WILL NEED TO REPLACE COVER TO MAKE 100%
Dealer Reported 01/30/2008 Mileage: 8523
*4 WHEEL ALIGNMENT - ALIGN - PERFORM 4 WHEEL ALIGNMENT
NON WARRANTABLE OPERATION CODE - ADVISE ON LEFT FRT TIRE ? - MOUNTED AND BALANCED NEW TIE - NOTE: WHEEL IS BENT
