Car will not start....HELP!!
Old 12-26-14, 09:57 AM
bawhite09
bawhite09's Avatar
Exclamation Car will not start....HELP!!
I am having a problem with my 2007 IS250. My car will not start. It is not the battery. I have had it tested, I have disconnected it, I have tried jumping it. Headlights come on, break lights come on when depressed, and interior lights come on. It is not the key fob battery either. The car is still able to be unlocked, locked, alarm set off, and pop trunk with it with no issues. When I depress the brake the green indicator light on the start button does not come on, however "ENGINE START/STOP" on the button is illuminated. Dashboard lights do not come on. Accessory mode does not come on. Engine doesn't start or turn over, no clicking noises, nothing. The door open light constantly stays on even with all the doors shut. Possibly in relation to this, my brake light will occasionally come on temporarily, but does not constantly stay on(not currently but before when car was running fine). Any clue? I am really trying to avoid having to tow it into the dealership!!
Old 12-27-14, 04:02 AM
jasonr
jasonr's Avatar
Get a OBDII device and check for codes. You might be able to find something.
Old 12-27-14, 10:14 AM
whitebeast
whitebeast's Avatar
try to depress your brake pedal harder
Old 12-27-14, 10:22 AM
brainsurge
brainsurge's Avatar
Check your battery connection, maybe a poor connection. ignition switch feels normal? do you hear the fuel pump?
Old 12-27-14, 01:19 PM
kornpeef
kornpeef's Avatar
Default no start or cranks but no start?
connect the batt. make sure you have a solid connections. let the car charge up for minute before starting it. press down on the brake pedal hard and make sure the green light is on the start button. you can also try placing the keyfob emblem side right onto the start button if the key fob batt is low.
Old 12-27-14, 01:21 PM
1sWt2GS
1sWt2GS's Avatar
alternator?
have u tried swapping another battery in?
Old 12-27-14, 03:46 PM
andy350
andy350's Avatar
without pressing the brake, press start button,
then again press start button and hold it for 10 seconds without pressing the brakes...
what happened?
Old 12-30-14, 04:06 AM
bawhite09
bawhite09's Avatar
I can't get a read with the car not starting.
Old 12-30-14, 04:07 AM
bawhite09
bawhite09's Avatar
Did that
Old 12-30-14, 04:08 AM
bawhite09
bawhite09's Avatar
No fuel pump, no clicking, no accessory mode.
Old 12-30-14, 04:11 AM
bawhite09
bawhite09's Avatar
That's the problem............the green light is not coming on when the brake is depressed. And it's not the brake switch or the battery, car battery or key fob battery. I've disconnected the battery to try and reset the ECU and I've tried jumping it. No blown fuses either.
Old 12-30-14, 04:12 AM
bawhite09
bawhite09's Avatar
what happened?
Nothing.....accessory mode won't even come on.
Old 12-30-14, 10:19 AM
kornpeef
kornpeef's Avatar
you sure u didnt jump it backwards? try checking the main fuse and see if its not blown.
Old 12-30-14, 10:39 AM
kornpeef
kornpeef's Avatar
nothing is gonna happen unless u get the green light on the start button to appear. if nothing is wrong with the batter like u stated i would place it back and hook it up. the batt will even out any voltage spikes and acts like a capacitor.
and double check that main fuse
Old 12-30-14, 11:22 AM
bawhite09
bawhite09's Avatar
I didn't check the main fuse yet, do that when I get home thanks
Quick Reply: Car will not start....HELP!!
