Engine Knocking
Old 12-11-14, 06:54 PM
fredkhaz
fredkhaz's Avatar
Default Engine Knocking
Hello everyone,
I just notices an extra knock in the engine of my 2006 IS350.
The Camshaft recalls and all other recalls are done.
update, this is a better video of the knocking... engine was warm.
It did stop and did not knock today....
Old 12-11-14, 09:46 PM
idoke1
idoke1's Avatar
It sounds some what normal to me. Does it run fine? Any codes stored in the ecu?
Old 12-12-14, 12:45 PM
fredkhaz
fredkhaz's Avatar
The knock went away, it runs fine and not codes. I think this is the 2nd time I have heard the knock at idle.
Old 12-12-14, 02:19 PM
NYKnick101
NYKnick101's Avatar
Was it on a cold startup?
Old 12-12-14, 06:50 PM
Smitslex
Smitslex's Avatar
Mine kind of sounds like that, i think the noise is normal. Our engines almost sound like diesels.
I miss the quiet engine of my is300
Old 12-12-14, 10:06 PM
fredkhaz
fredkhaz's Avatar
Old 12-13-14, 03:28 PM
Gville350
Gville350's Avatar
The ticking is normal, but there doesn't sounds like another noise in there. Could be a failing water pump; the WP is the most notorious failure item on the 2IS unfortunately. Have you had your WP replaced before?
Old 12-13-14, 06:05 PM
fredkhaz
fredkhaz's Avatar
The camshaft recall was done at 100k miles and waterpump was replaced then. I will double check.
It happened twice so far that I noticed.
it is not knocking now.
Old 10-11-15, 01:53 PM
LCBooth
LCBooth's Avatar
Default white smoke and loud engine knocking 92 es300
Starting the car, white smoke blowing out of the tailpipe and eventually goes away, along with a loud hammering or clacking sound from the top of the engine, no matter if in idle or revving, knocking is the same. Any clue where I should look to fix this issue? Thanks ☺
Old 10-12-15, 03:47 PM
A1cntrler
A1cntrler's Avatar
You should probably start a new thread with your issues to get better help tailored towards your specific problem. Also post it in the ES forums, not the IS forums.
Is the "white smoke" sweet smelling? How is your oil? Does it look milky? Might be a head gasket issue if any of the above is true.
Old 10-12-15, 05:55 PM
srt1
srt1's Avatar
^ Ditto
Cargrub
ES - 6th Gen (2013-2018)
07-08-19 11:46 AM
goldenrod
Performance & Maintenance
03-15-18 04:54 PM
noh626
05-09-15 05:32 PM
A.C Milan
05-23-07 04:28 PM
tpizarro
07-16-06 07:49 AM
Quick Reply: Engine Knocking
