What Handling/Suspension Parts to get???
Old 12-01-14, 11:05 AM
Nixcision
Nixcision's Avatar
I personally would recommend a front strut tower bar. It adds to the appearance of the engine bay and might offer a tiny bit of stability in the corners... overall just for appearance!
Old 12-01-14, 04:03 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Here you can see some of the parts including the F Sport sway bars, Megan LP coil overs, Megan camber arms, F Sport chassis brace, big brake kit with stainless brake lines, the red Tanabe lower brace towards the front and the Jun TW center tunnel brace which is yellow in front of the chassis brace in the center of the car.
Attached Thumbnails What Handling/Suspension Parts to get???-suspension-pic.jpg
Old 12-01-14, 09:42 PM
Rudebwoy30
Rudebwoy30's Avatar
Looks good. Thanks for the visual Sffd103. Would it be more effective and maybe add a tiny bit more stiffness if i upgraded the sway bar end links with aftermarket ones?
Old 12-02-14, 09:46 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
IS250 and IS350 sway bars are identical, that said there are different factory sway bars depending on year and whether or not the car has the Sport/F-Sport Package. Still the same for IS250/350 though, given the same year and suspension package.
Jeff
Old 12-02-14, 12:42 PM
Gville350
Gville350's Avatar
Oh, I forgot about an OS Giken LSD!
Old 12-02-14, 12:58 PM
Keo
Keo's Avatar
Originally Posted by Rudebwoy30
Hi everyone, its been a while. I have an 08 IS 250 with Tein s tech springs and Track Wheels, I was wondering what other upgrades i can do for the car to handle and feel more balanced as i drive and take corners. I will be purchasing the F sport Rear Sway bar soon as it seems to be a must do. Besides coilovers, what other parts can i add to stiffen up the ride, handle, feel more stable and solid?
Besides coilovers, Probably get some performance Shocks/Struts? Since you already getting the sways and everyone here is mentioning it. Also the more lower the car is the more center gravity u have for stiff control. Correct me if I'm wrong. I have Tokico Blues its a great alternative for performance shocks. Recommend F-Sport( Bilstien ) & Koni's.
Old 12-02-14, 03:28 PM
Sportskid1
Sportskid1's Avatar
God I want one! Why can mustangs get a good LSD for $500 when we have to spend $2500?
Old 12-02-14, 04:30 PM
FSportIS
FSportIS's Avatar
If you prefer "tail" happy a bit oversteering like i do, get the rear sway bar only. I power slide/drift the IS350 so damn fun in autocross. It is harder to do with the IS250 due to less torque.
If you want to neutralize the car (no understeer, no oversteer), get both front and rear sway bar, this set up helps better lap times but you don't get much of the crazy fish tail effect easily like you can with the rear sway bar only.
Again for better handling and pushing the car hard, tires tires tires... I can't stress this enough lol. It makes a whole lot different. If you have the money, go for semi-slick like the Michelin Sport Cup or whatever that is even though they don't last that long on street. If not, go for high performance summer tires like the Hankook V12 or Michelin Pilot Super Sport.
Next is coil coil coil where you can adjust the dampening settings, go for KW V3 stiffen it up and zroooommmmm
If you want even more, put your car on diet, do weight reduction, change seat to lightweight race seats. Even more, install roll bars .... the list is endless lol
Old 12-02-14, 05:06 PM
redspencer
OG Member
redspencer's Avatar
Though not a suspension part, one indirect handling upgrade that I enjoy on a daily basis is the IS-F Steering ECU. It will dramatically improve the steering feel over the stock ISx50 Steering ECU and make your daily drive much more enjoyable while inspiring confidence when taking the car to its cornering limits.
Old 12-02-14, 06:45 PM
Rudebwoy30
Rudebwoy30's Avatar
Your right the list goes on. I willl be starting out with the sway bar set and some stickier tires like you all said. And possibly some of those braces that were previously said here and also in other threads. WIll not be tracking the car. I have an ISlow250
Old 12-02-14, 07:30 PM
Sffd103
Fire Slayer
Sffd103's Avatar
That I don't know enough to comment on.
If he gets coilovers he won't need shocks/struts. They're already involved with coils.
Old 12-02-14, 08:50 PM
Keo
Keo's Avatar
It's just that he mention in his first post about any other things beside coilovers. He mention he have Tien Spring only. I would assume he have stock shocks. Swap it out with a new or good used Aftermarket shocks and he'll feel the difference with an addition to those sways.
Old 12-03-14, 07:52 AM
Rudebwoy30
Rudebwoy30's Avatar
Yes i do have factory shocks with Tein S tech springs. Will be considering aftermarket shocks, if the factory ones start to feel blown, or when they blow lol
Old 12-03-14, 06:57 PM
A_Grasso
A_Grasso's Avatar
Just get yourself BC coilovers with higher rates and swift springs. Don't forget good tires though. The f sport sways help a lot as well
Old 12-03-14, 09:46 PM
Rudebwoy30
Rudebwoy30's Avatar
Yes... Ordering F sport sways as a xmas gift to self... Cant wait!!!
lexuscrit
Suspension and Brakes
02-23-13 09:14 AM
mong
16
11-12-11 06:10 AM
blklexo818
32
10-20-11 04:29 AM
Fuzzie
02-28-10 06:32 PM
S to the K
05-16-08 12:15 PM
Quick Reply: What Handling/Suspension Parts to get???
