No Powersteering, Power windows. ABS, P/S, Brake, AFS OFF lights ON! Help!
I recently bought some 10K, LED Headlights and installed the motor from Stock headlights in order to move bulbs up and down.
AFS OFF starting flashing so I read a thread saying to disconnect the smaller connector to the blue box behind floor mat on the driver's side. Then when I saw the AFS OFF light missing I was happy, just find out my steering is sooo stiff, no power windows, dash showed parking brake, ABS, P/S, the picture of a person and airbag lights on. Don't know what to do. I checked all the fuses. I tried reconnecting that connector and disconnected battery in order to reset everything but still, all same problems. I also think my A/C isn't working. Has anyone had this problem before? I'll take pictures soon.
I bought the manual and reviewed the fuse setup on passenger side. The fuses were all mixed up.
Fuses 1,7 and 12 are closest to the passenger seat. Fuses 6, 11 and 17 are towards the front of the car.
Fixed.
After rearranging the fuses everything was good.
And yes I put the motors from the OEM headlights to my new ones and it moves up and down, not left and right. Which doesn't bother me much and the AFS OFF light is off so that's a plus.
fuses are in the right spot
[QUOTE=BatmanKaos;8762650]After rearranging the fuses everything was good.
And yes I put the motors from the OEM headlights to my new ones and it moves up and down, not left and right. Which doesn't bother me much and the AFS OFF light is off so that'h
Having that same problem. Checked the fuses they are all in the right spot on both sides driver and passenger
When my naviagation system went blank the dealership checked my fuses and stated they were all ok and working. After reading this I went and look under my hood and took the lid off that fuse box and noticed like a 20A is where it says 15A There all mixed up. Does this matter. Again I'm female and only learning what I learn on here. Thanks
chargers11
11-23-17 02:40 PM
Aamirsc400
07-05-15 09:22 AM
