Anyone having issues pairing iphone 6
Old 10-02-14, 06:12 AM
jbone29
jbone29's Avatar
Default Anyone having issues pairing iphone 6
Just got the Iphone 6 and it will not pair in my car. I've had 4 other iphones pair with no issues. Any suggestions.
Old 10-02-14, 06:40 AM
eplugplay
eplugplay's Avatar
Looks like iOS 8 is causing bluetooth connectivity issues.
http://www.macrumors.com/2014/10/01/...tivity-issues/
Old 10-02-14, 07:59 AM
alexs350
alexs350's Avatar
I paired my iPhone 6 plus as my music to 2012 is350 perfectly fine.
Old 10-02-14, 09:00 AM
jbone29
jbone29's Avatar
Maybe its my 2007 model, i will try again today. I have the latest update from Apple. So frustrating!!
Old 10-02-14, 09:56 AM
604GSE21
604GSE21's Avatar
my 06 paired just fine with the iPhone 6...
Old 10-02-14, 10:17 AM
eplugplay
eplugplay's Avatar
Specifically, I meant previous versions before 8.1 is causing issues with bluetooth connectivity and that 8.1 will solve it. Have you updated to the latest 8.1 firmware? This should fix the issue.
Old 10-02-14, 10:54 AM
rparkzy
rparkzy's Avatar
i had some issues in the beginning too.
i deleted all my other devices paired to the car first then paired the new phone to the car as a brand new device. it worked after that. then i had to reset the bluetooth settings for the music portion manually as well and repair to the new device as it was recognizing the old one.
Old 10-02-14, 05:13 PM
giddyupca
giddyupca's Avatar
my 6 paired ok to my 09 is250 but if i use Siri and request it to all a person, it looks like it starts and then nothing, must be a qlich
Old 10-09-14, 03:01 PM
Cgmiller63
Cgmiller63's Avatar
I'm having the same issue.
Old 10-09-14, 04:38 PM
Kd0t
Kd0t's Avatar
Okay so I figured this out..
There's 2 different ways to pair your phone and 2 different functions.
You can pair the phone to use for calls by simply connecting your iPhone to the car's phone setting.
Note: this option has 4 phones you can pair. However, this will not let you play your songs via bluetooth.
The car only has 2 available slots for devices to connect bluetooth audio. And the setting is located where you change your devices to connect to bluetooth audio. If I remember correctly, settings > audio > select bluetooth player or something like that.
Good luck
Old 10-10-14, 06:23 PM
babaliont
babaliont's Avatar
iOS 8.1 has not been released yet. The latest is 8.0.2 and it does NOT fix any of the BT and USB connectivity problems.
Old 10-10-14, 07:05 PM
jbone29
jbone29's Avatar
Finally got it to work! First i tried restore network settings but that did not work. What did it was I deleted all my previous phones and it paired right up.
gswatson
04-04-19 02:39 PM
sessayan
09-26-14 11:31 PM
bobbyt01nc
05-17-09 05:23 PM
tightlinez
GX - 1st Gen (2004-2009)
02-09-09 11:02 AM
Dogmeat
CL of Southern California
09-05-08 07:26 AM
Quick Reply: Anyone having issues pairing iphone 6
