IS350 Cold Start Noise!!!!!HELP!!!!!!
Old 09-24-14, 09:23 AM
flameazn
flameazn's Avatar
Default IS350 Cold Start Noise!!!!!HELP!!!!!!
Having a problem on my car when is cold start. Before is not that loud, now is getting louder and louder. I have done every recall, but the last one i did was the cam gear, is that normal about the sound like this? If that the problem come out from the cam gear recall, will Lexus still will respond for this noise, because i have done the recall about 6 months already.
Old 09-24-14, 09:34 AM
got556
got556's Avatar
Damn near sounds like a diesel F350 lol.
Old 09-24-14, 11:32 AM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default .......................
If i was you i would take it back to them and tell them that its been making that noise since the re-call was done but you thought it would go away since you were aware they had fixed the cams but it has been progressively gotten worse.
Let them deal with it. The noise was not there before the re-call right??
Old 09-24-14, 12:08 PM
idoke1
idoke1's Avatar
Thats a wierd noise. Does not sound like the cam gear rattle. It could be the pulley being too tight.... its a high pitch sound.
Old 09-24-14, 12:14 PM
synrgy350
synrgy350's Avatar
You have a lot of coolant residue on your hoses and surrounding areas. Did you have your waterpump replaced recently? I would also watch out for that if you have not.
Old 09-24-14, 03:18 PM
NYKnick101
NYKnick101's Avatar
Sounds like your waterpump at first but then it goes away once the car gets warm which is weird. Have you ever had it done? See if you can get it on a lift and isolate the sound? Does is it loud on the Left/Right/Front/Back of the engine. If its is front only, I would be almost positive that it is the water pump and/or pulley assembly
Old 09-24-14, 04:38 PM
Pearlexus1
Pearlexus1's Avatar
did someone lose their dice? interesting sound o_O
Old 09-24-14, 05:52 PM
06350F
06350F's Avatar
Go to YouTube and punch in cold start noise or check under my started threads. Might look at your alternator pullie or water pump
Old 09-24-14, 10:38 PM
flameazn
flameazn's Avatar
I didn't replace the water pump, the coolant all around because i went to track last time, and it was a little bit over heat, the coolant cap pop out a bit. And i stop the car right away. So thats why.
Old 09-24-14, 10:40 PM
flameazn
flameazn's Avatar
I don't think so. I have not do anything to the engine.
Old 09-24-14, 10:41 PM
flameazn
flameazn's Avatar
Before the recall, the noise is here, but not loud like now
Old 09-24-14, 10:45 PM
flameazn
flameazn's Avatar
So how many miles you think i should replace the water pump. I don't know about car. Currently i am at 101K miles. And do you know how much will cost about for this job?
Old 09-29-14, 06:51 AM
NYKnick101
NYKnick101's Avatar
most shops will charge in the $500+ area. IDK if your handy with a wrench but there is a few DIY's on the site and the job is easy IMO. the water pump is on the front of the engine which is easily accessible and easy to remove and replace
Sexus99
07-22-15 08:58 PM
PureZ
04-02-14 02:38 PM
Gymniac
03-22-14 03:50 PM
06350F
03-20-14 05:36 AM
Hulahoo
04-19-07 07:54 AM
Quick Reply: IS350 Cold Start Noise!!!!!HELP!!!!!!
