o2 sensor
Old 09-08-14, 08:27 PM
Fsport22
Fsport22's Avatar
Default o2 sensor
is it easy to take off the 2 o2 sensor on the mid pipes
Old 09-09-14, 12:27 PM
Gville350
Gville350's Avatar
With the car off the ground (lift or stands) AND with the RIGHT TOOLS, yes. Spray some PB Blaster on it first before removal. If needed, have some HEAT handy (propane torch).
Old 09-09-14, 04:40 PM
Fsport22
Fsport22's Avatar
do u need a special tool or and if so wat kind
Old 09-09-14, 05:45 PM
Gville350
Gville350's Avatar
Old 09-09-14, 07:13 PM
oblivionis
oblivionis's Avatar
I say it depends on how old the car is. I couldn't take it off on my 2006 and I had the special tool. Took it to a mechanic and was told that they won't be able to remove it workout breaking it.
Old 09-09-14, 07:18 PM
synrgy350
synrgy350's Avatar
You want the o2 socket designed for toyota, the standard long socket won't fit on the mid pipe sensors.
I got mine from Ebay. Also, it makes it way easier when the car is on a lift so you can get a long breaker bar on it.
justYnG
IS - 1st Gen (2001-2005)
06-08-15 06:10 PM
2jKarma
05-10-14 01:10 PM
cjlazar84
Performance
25
02-17-10 10:20 PM
PoorMan'sR
08-12-09 02:34 PM
carcass66
05-30-04 01:28 PM
Quick Reply: o2 sensor
