19x10 19x11 +10 with just a roll and some camber?
Old 09-06-14, 01:44 AM
  #31
BoyOhBoy
BoyOhBoy's Avatar
Originally Posted by VDMTom
19x10 +12 is pretty easy to fit. I had 10 +15 before with 265, no big struggle.. just fender shave and rear camber arm Front is a tad bit aggressive, but nothing a 225 or 235 won't fix.
Hahaha thanks for the advice once again. Got me pumped up! Ya it comes with 225/35 front and 235/35 rear. If I have trouble, I'm going to sell them to go 215/35 front and rear
Old 09-08-14, 08:21 PM
  #32
LoveThatV8
LoveThatV8's Avatar
Damn those are crazy sick offsets for a 2is. I wanna see the end results.
Just incase you wanna do the more aggressive setup still. Since the 2IS and 3GS have very similar fenders.. Maybe I can help you out.
My last setup, I ran a 19x9.5 +15 / 19x10.5 +15 with 225/35/19 255/35/19 (kind of meaty) with -3/-5.5 camber no issues other than shaving front and rear fenders. I have rear Megan arms. 2 upper camber + 1 toe arm. The rear can go to about -6.. I was tucking rear tire cleanly in the rear and can have ppl sit in the back. Front I was about tucking top of tire. Can turn fully and easily still.
Basically that was a 19x10 +21 and 19x11 +21. In order to run +10, you'll need to run to run 225/245 with a really good alignment, you can make +10 work.
My new setup which isn't here yet will be 19x10 +25 and 19x11 +20.. running a bit safer in the front cause I'm going to do 235/35/19 and 265/30/19 this time + I have my front Megan camber arm ready I'm not too much of a fan of lots of stretch.. rather keep replacing rear tires than have a bead pop.
What you'll need:
Megan Racing Rear Adj. No.2 Upper Arm (Back ordered for another month, most important arm)
Megan Racing Rear Adj. No.1 Upper Arm
Megan Racing Rear Toe Arm
Megan Racing Front Upper Camber Arm
REALLY GOOD fender shave for rear, good shave/roll for the front.
Alignment - 3.75, -6 camber if you're slammed.
Andrew, I can source the parts for you if you like. I helped you when I was at Sonic MS
Looks like you're my offset guru... You and yogi fatlace, since both of you have a near same offset as me. Can i get away with 19x9.5/10.5 +22 with no camber arms? I've done my search on 3GS wheel thread but very few run those offset and figured to ask you. I'm on DF210 front rolled and rears shaved for my 3GS. I already have Volks CE28N time attacks sitting next to me. LOL.
Old 09-09-14, 03:43 AM
  #33
stewb10
stewb10's Avatar
Originally Posted by jdmSW20
on a 19x11 +10 sure it wil work in the rear with fender work i currently run a 19x11 and 265/30 rear tire setup. even with roll and pull and -5 degrees of camber its barely fitting for a stock body setup. plus my car is slammed, so down to a +10, thats not going to work stock body, unless his car is stock height. ive seen 19x11 +20 with a 245/35 on the rear of a is250 stock body and it barely fit as well. i have megan rear camber arms and maxed out, i barely got to -5 camber http://i1197.photobucket.com/albums/aa429/WARxxMACHINE27/Snapbucket/219D928C_zpsf63a3f63.jpg This 19x11 rear with 265/30 tire and -5 camber. So another 15mm past that... Not happening on stock body unless the OP wants to try like -10 camber
Ill be fitting 19x11.5 w/ single digit offsets today, so I'll post pictures later. This convo has more to do with spring rates than anything else. Only way they wont fit is if you want to tuck them inside your fenders. Silly static people.
19x10.5 -6 here, before the last few tweaks to get it flush. My new offsets will be +/- 5 from here on a 11.5 265/30.
Old 09-09-14, 03:15 PM
  #34
MrBalistic
MrBalistic's Avatar
I ran 20x11 +11 offset lowered and with megan racing camber kit fully adjusted and all I needed was a roll and slight pull. so I think 19x11 with a roll should be good. what offset are yur wheels?
Old 09-09-14, 05:39 PM
  #35
stewb10
stewb10's Avatar
As promised
Old 09-09-14, 05:44 PM
  #36
zackteee
zackteee's Avatar
Originally Posted by stewb10
As promised
Looks perfect
Old 09-09-14, 06:06 PM
  #37
BoyOhBoy
BoyOhBoy's Avatar
As promised
Attachment 341590
Wow, just wow! I want this kinda fitment with my next set of wheels. Did you like max your camber arms and then work back from there?
Old 09-09-14, 07:42 PM
  #38
Sffd103
Fire Slayer
Sffd103's Avatar
As promised
Attachment 341590
That looks tight!!!!
Old 09-09-14, 11:58 PM
  #39
jdmSW20
jdmSW20's Avatar
Attachment 341547
lol yeah but im one of the silly static people and almost just as low as most cars on air, air'd out haha. fitting those specs with air to me is a different convo. since you can air up to almost stock height and not rub at all lol. but i think the OP is going to be static. so being static, with those specs, and having a good legit stance... thats going to take alot of pulling beyond what i consider stock body anymore. but to each his own, i know different strokes for different folks
As promised
Attachment 341590
that is looking sick though
Old 09-10-14, 02:55 AM
  #40
BoyOhBoy
BoyOhBoy's Avatar
Yeah, I figured there is way too much work trying to fit those so I resorted to a different set that popped up. I put the specs on the first page!
Old 09-10-14, 08:13 AM
  #41
stewb10
stewb10's Avatar
I definitely see where you're coming from on that, we just have different definitions of stock body. to me, no matter how much you pull, as long as you don't need paint, filler, welding, cutting, thats stock body. And FWIW, these will actually tuck. My perches were too low, and they were sliding right up inside the fender. Granted, I have a PERFECTLY flush fender roll. With a bit more work, these rears would be able to be rolled static. The fronts, not a chance.
Old 09-10-14, 04:16 PM
  #42
jdmSW20
jdmSW20's Avatar
yeah i agree man, ive come to learn there is a multitude of definitions on stock body. like to me once you have pulled so much, it doesnt look stock anymore, in my own opinion thats not stock body anymore. but i definitely agree with you on once you need paint/filler/welding, its definitely not stock body anymore lol
but a front spec that aggressive, and static, yeah that aint happening. not with a nice legit stance. i know some folks will run aggressive specs and the car wont be as low to look legit. those people i dont even acknowledge lol
Old 09-28-14, 02:34 AM
  #43
VDMTom
VDMTom's Avatar
You need to decide what size tires to run.. without camber arms, it may look sort of weird anyway. Adding a bit of camber/correcting toe with the arms will help your tire wear also.
I highly suggest you do coilovers to help get the correct clean look.
2jNoise401
04-27-16 04:38 PM
bowflex21
Suspension and Brakes
05-10-11 06:18 AM
ZSC3
IS - 1st Gen (2001-2005)
11-09-10 10:35 AM
RidinLow
01-30-09 08:00 PM
mikemareen
09-04-08 12:23 PM
Quick Reply: 19x10 19x11 +10 with just a roll and some camber?
