Rough idle, from using accessories???
Old 08-21-14, 01:39 AM
Fizzboy7
Fizzboy7's Avatar
Default Rough idle, from using accessories???
I have had the carbon buildup issue for most of my car's life, and recently had the pistons replaced. That got rid of the almost stalling issue after coming to a stop, but I still have a rough idle a few miles per hour before the car comes to a complete stop. What's a bit more strange is the same rough idle momentarily kicks in when I use accessories for the car. This includes the turn signal, power windows, or other things that draw power. What would one conclude is going on here? Could this still be related to carbon buildup even with brand new pistons, or is something else wacked, like spark plugs, etc?
Old 08-21-14, 05:33 AM
amw896
amw896's Avatar
This is the second post ive seen about this recently but i cant seem to find the other post now. I would say have your battery and alternator inspected as it definitely sounds electrical related.
Old 08-21-14, 07:11 AM
robtwo
robtwo's Avatar
Every now and again when I start the car warm and the AC puts a lot of load on the motor I get a slightly rough idle.
I figure I might have to relearn idle on the car from cold.
Old 08-21-14, 12:23 PM
Gville350
Gville350's Avatar
After you had the car into Lexus for that repair, have you disconnected the battery to force the car to reset and re-learn everything? If not, I'd highly recommend it. Perhaps some MAF cleaner spray too.
Old 08-21-14, 11:32 PM
Fizzboy7
Fizzboy7's Avatar
I'm going to have to search for that. Very interested in what that may have been.
Old 08-21-14, 11:34 PM
Fizzboy7
Fizzboy7's Avatar
Oddly, my idle smooths out with the A/C on. I guess it's the constant higher rpm.
When I got the car back after the piston/engine rebuild, all my settings were still there. But the battery/alternator idea is worth checking. Thanks for your input.
Old 08-23-14, 08:49 AM
Gville350
Gville350's Avatar
^They didn't disconnect the battery when replacing the pistons (aka, removing the entire motor)? WOW!
jj813
IS F (2008-2014)
11-11-13 09:56 AM
derbrylac
09-20-12 08:38 AM
Fizzboy7
04-17-12 02:02 AM
SC3coupe
07-08-10 04:30 PM
Quick Reply: Rough idle, from using accessories???
