Will I rub?
Old 08-19-14, 07:07 AM
Amuse350z
Amuse350z's Avatar
Default Will I rub?
Thinking about going for this set up..
19x9.5 + 32
19x10.5 + 28
or
19x9.5 + 32
19x10.5 + 22
currently on stock struts, H&R Springs.....
Is this too aggressive for daily driving? Or is this set up just not ideal?
Really contemplating on getting the +22 in the rear but wanted everyone's input...
Old 08-19-14, 09:04 AM
Jaytea
Jaytea's Avatar
My concavos are 20x10.5 + 45 in the rear and I barely had room to clear. I also ran my tires with 275/30/20. Hope it helps
Old 08-19-14, 11:44 AM
Amuse350z
Amuse350z's Avatar
if I get 19's, wouldn't I still have more room to clear than your 20s?
Old 08-19-14, 05:01 PM
jdmSW20
jdmSW20's Avatar
your clearance wont be an issue at all. but those wheel specs and not dropped, its going to look mexiflush. since a 19x10.5 +22 is pretty aggressive
you also need to factor in what are your tire specs going to be? we need more info
Old 08-19-14, 05:09 PM
Gville350
Gville350's Avatar
Depends, what tires do you plan to run with each size of wheel? I've got Genesis "Track" wheels (19x8 & 19x8.5) with 225/35 & 245/35 tires. I have to mention I'm lowered a good bit on BCRs at 24.75 up front and 25 in the rear. Both wheels are a 35 offset, but I had to run a 5mm spacer in the front; so the front is basically a 30 offset.
With that all said, I had to do the "bumper tab" mod and had been running w/o front wheel liners. I slightly pulled the fenders as well. But no cut or rolled fenders.
Seeing your not nearly as low as I am, I don't think you'll have a problem with the front setup at all with at least a bumper tab mod. The rears I feel would be fine as well; but I'll let someone else running a more aggressive/larger wheel answer to that.
Old 08-21-14, 05:08 AM
Amuse350z
Amuse350z's Avatar
OH it's dropped on H&R Springs... what tire sizes would you recommend?
Old 08-21-14, 07:04 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Basically you won't be able to just slap those on without doing some modifications to the car. I had 225/30/20 and 255/30/20 for tires. Those are pretty perfect with a slight stretch and there's room. You will probably still have to roll your fenders/ quarter panels and do that bumper tab modification.
Old 08-21-14, 09:34 AM
Kd0t
Kd0t's Avatar
Your setup is very similar to mine (installing this weekend)
I have 19x8.5 +27
19x10.5+22
The rears will need to be rolled.
Tire sizes: 225/35 & 255/35
Good luck!
Old 08-21-14, 03:55 PM
jdmSW20
jdmSW20's Avatar
agreed with the bold parts of the statement
Old 08-21-14, 06:33 PM
PawnStar23
PawnStar23's Avatar
I'm also on h&r springs and i plan on to run 19x9.5 +22 and 19x10.5 +22 but not sure if that's too aggressive for daily driving on springs.
Old 08-21-14, 10:57 PM
jdmSW20
jdmSW20's Avatar
without a significant drop and those wheels specs, its going to look mexiflush. especially if you have any kind of tire stretch
Old 08-22-14, 01:09 AM
JusticeK
JusticeK's Avatar
Yeah its gonna look ugly. Those are standard flush specs but you gotta be on coils or air imo. H&Rs I would go down a inch and be somewhere like 8.5 +22 and 9.5 +22. It will be more conservative but it will give you a overall clean look.
Jay
Old 08-22-14, 01:26 AM
Amuse350z
Amuse350z's Avatar
What if i went with +28mm? on the rear offset 10.5? Will I still need to roll the rear fenders? I just don't want to put extra work into the body work if not needed..
Old 08-22-14, 07:03 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Yes you will. A 35+ will not require any work.
Old 08-22-14, 07:52 AM
jamespoco
jamespoco's Avatar
Will the +32 clear the front brakes?
Quick Reply: Will I rub?
