IS250 left me stranded with no electrical power at all
Old 08-11-14, 01:46 PM
EXL124
EXL124's Avatar
Default IS250 left me stranded with no electrical power at all
Had an odd experience this weekend with my IS. Ran some normal errands and was on my last stop. Came out to the car and touched the door handle to unlock. It unlocked and I got in and within 5 sec, I reached for the start button and nothing happened. Nada....no power at all. Checked the dome lights, my headlights...nothing, and yet my doors unlocked 5 sec ago. Went out checked my terminals and a few fuses...looked good. Ultimately called a tow truck and the guy came out with his battery charger to jump it. Nothing again. His charger read 12.5v. Had it towed to my mechanic.
I got word from my mechanic today that it was a dead battery. He swapped it with a new battery and it started right up. Is anyone able to explain to me how the tow truck guy tried a jump and it did nothing while swapping out the battery worked like a charm? I could understand it the tow guy hooked up the battery to his charger and I got a weak current through...but it was totally dead.
Old 08-11-14, 03:28 PM
RangerJoe
RangerJoe's Avatar
It is possible the dead battery was causing a short or something, which could interfere with a jump. I had a battery go bad while driving about a year and a half ago. Hit my blinker to change lanes cruising on the highway, dash lights went out and the needles dropped, headlights flashed off, radio stopped, but the car kept driving. Drove another 2 hours home. As soon as I shut the car off, it was completely dead. No lights, no locks, nothing.
Basically, bad batteries can cause all sorts of strange problems. It's a hassle when they go with no warning like that though.
Old 08-11-14, 03:50 PM
MikeFoxx
MikeFoxx's Avatar
yeah dead batteries def cause all sorts of strange problems to say the least. last friday I moved my spouses Sonata and yesterday I went to pop the trunk with the key fob and it didn't move. Got the other key fob thinking it was the battery in the fob... nothing. opened the door which was already unlocked int he garage and no lights, no door open signal, no power seats... I pushed the trunk release... Nothing. Just for the heck of it i pushed the gas tank door release... it clicked but would not open.
Pulled the battery got it tested... 8volts... 2 days prior not a single issue. all doors were shut and nothing was left on in between those events. Tossed in the new battery and its all good. Guess it would suck to have a dead battery and need gas in our Sonata.
Old 08-11-14, 05:47 PM
curtisR
curtisR's Avatar
Same thing happened with me, it ended up being a bad ground from the battery.
Old 08-11-14, 05:59 PM
Mike_1GO
Mike_1GO's Avatar
always make sure your terminals are clean from oxidation. that helps prevent any bad connections.
Old 08-11-14, 06:18 PM
4TehNguyen
4TehNguyen's Avatar
batteries act weird when they die. Always get suspicious of your battery when it hits the 3-4 year mark, and they like to die when the weather is hot without warning
Old 08-11-14, 07:24 PM
NikonGuy
NikonGuy's Avatar
I believe my 2008 IS with 76k is still on original battery
Old 08-12-14, 06:11 AM
Boomin
Boomin's Avatar
Save your self the head ache and get xp 2400. I had my stinger sp1500 since 06 and just now died.
YouTube Steve Meade Lexus battery swap
Old 08-12-14, 03:53 PM
Sceanzo
Sceanzo's Avatar
Your battery had what's called a dead short. A dead short in a battery will kill a jump box in seconds.
lexier
10-18-18 02:16 PM
Trogdor796
04-18-16 09:50 AM
gxman1
GX - 1st Gen (2003-2009)
05-08-14 09:41 AM
cgawelko
12
04-17-14 12:47 AM
KilaWombat
20
05-24-08 04:26 AM
Quick Reply: IS250 left me stranded with no electrical power at all
