Tire pressure - Z-rated tires
Old 08-09-14, 05:59 PM
bryan11
bryan11's Avatar
Default Tire pressure - Z-rated tires
My 2008 IS350 RWD with the sport package and 18" wheels came with a set of z-rated summer tires. I'm driving mostly with my family and am looking for comfortable driving with the ability for fast lane changes and such when needed. Max cold pressure on the tire is 51psi, but all tires were at 36psi when I purchased it. The manual says for my tire size, pressures should be 35psi front and 38psi rear.
What tire pressure do you prefer? Should they be different front and back?
Old 08-09-14, 06:14 PM
darkdream
darkdream's Avatar
I use recommended pressure. Car feels like it is floating compared to my S2000.
Old 08-10-14, 11:22 AM
Gville350
Gville350's Avatar
36 is right about where I'd run them.
Old 08-11-14, 03:32 PM
RangerJoe
RangerJoe's Avatar
Definitely go recommended pressure. And make sure you are checking the pressure when the tires are warm, not cold. Drive on them for 20 minutes and check. It likely won't make more than a few pounds of difference, but it can effect tire wear.
Old 08-11-14, 04:52 PM
PondScum
PondScum's Avatar
That's wrong. For a passenger car, tire pressures should be measured when the tires are cold.
If I underinflate my tires, the excess flexing of the carcass will heat the tire, thereby increasing the pressure, and it will register the recommended pressure if I measure when the tire is warm (after driving on it). But the tire will be underinflated. That's why tire pressures are specified for cold tires.
On a race car you're trying to achieve certain spring rates with tire pressure, so the tire pressure when the tire comes up to temperature matters (though unless you've got tire warmers you're setting the pressure when the tire is cold, and calculating where it will be when warm).
Old 08-12-14, 06:32 PM
RangerJoe
RangerJoe's Avatar
I stand corrected. I have apparently been reading too many racing forums. This guy is right for passenger cars.
cezar9
01-11-16 06:05 PM
charlesatl
12-15-15 09:03 AM
lexman52
11-29-15 02:04 PM
IS350SWFL
04-30-15 11:34 PM
LXOGOOD
Wheels, Tires & Brakes Forum
06-29-02 10:48 PM
Quick Reply: Tire pressure - Z-rated tires
