Megan rear camber kit- Use nylon locking nut or OEM?
Old 08-08-14, 05:21 PM
dfwjohnd
dfwjohnd's Avatar
Default Megan rear camber kit- Use nylon locking nut or OEM?
Which one did you guys use?
Old 08-08-14, 05:26 PM
dfwjohnd
dfwjohnd's Avatar
About to get pictures up
Old 08-08-14, 06:35 PM
WylieKylie
WylieKylie's Avatar
OEM, all day, every day, and twice on Sunday. I also suggest you buy a new set of OEM nuts. OEM are locknuts too.
Old 08-08-14, 06:56 PM
jdmSW20
jdmSW20's Avatar
i used the oem ones with my megan rear camber kit
Old 08-08-14, 07:15 PM
Sffd103
Fire Slayer
Sffd103's Avatar
I used my oem ones
Old 08-08-14, 07:54 PM
dfwjohnd
dfwjohnd's Avatar
i guess no pics needed, OEM it is
Old 08-09-14, 09:59 AM
Gville350
Gville350's Avatar
I used the locking nuts with left-over THICK washers I had just sitting around. Reason I did this was because when installing the first OEM nut back onto the ball joint portion of the camber arm, the thing got stuck halfway on and I couldn't get it off or all of the way on. Once stuck, the ball joint itself just spun in the socket leaving me SOL. So I ended up having to Dremel the ball joint threaded stud off and had to purchase a replacement from Megan. It became a much more expensive mod that I would have figured because of that.
AZGHOST
Suspension and Brakes
37
05-12-21 03:26 PM
staylurkin
04-18-17 09:53 PM
xspsi6
46
01-16-14 10:07 AM
llllllllll
IS - 1st Gen (2001-2005)
07-13-10 06:22 PM
Quick Reply: Megan rear camber kit- Use nylon locking nut or OEM?
