Custom Grille
Old 08-05-14, 06:43 AM
PhiGam27
PhiGam27's Avatar
Default Custom Grille
Well after a buddy of mine bashed my front end in, I got it fixed and asked the shop to put the old grille, grille surround, and emblem in my trunk since they were replacing it. I decided to make a custom grille like a did a few years ago on a Mazda that I had. I went to walmart and purchased a large sheet of aluminum mesh and cut it to fit and spend a couple hours bending and trimming to fit in perfectly. After about 20 cuts on my hands and a few hours of work I think it turned out pretty well. The main goal was to look good and be able to see the hella horns through very well. I went ahead and through some plastidip on it for the time being. black for the grille and white for the emblem. I used white floral wire to attach the emblem which worked pretty well. Now all I have to do is switch the insert over to the good surround and it will be done. Here is a test fit with the old surround.
Let me know what you think.
Old 08-05-14, 07:30 AM
RDIS250AWD
RDIS250AWD's Avatar
is it just me or is the picture so small even at full size? kind of hard to tell what you did
Old 08-05-14, 07:32 AM
PhiGam27
PhiGam27's Avatar
I noticed that but I cannot seem to make it any bigger. I emailed it from my phone to get it on my computer and I can open it up on my computer full size and it looks just fine. I do not know what happened in between here and there.
Old 08-05-14, 05:08 PM
rawr2is250
rawr2is250's Avatar
Hard to see it. Try using photobucket to resize.
Old 08-06-14, 08:08 AM
PhiGam27
PhiGam27's Avatar
Okay. I resized it, enhanced it as best I could and increased the brightness. This is about the best I can do. I will be switching the grille surrounds tomorrow and actually installing it so I will try to get a better picture then as well.
Old 08-06-14, 08:35 AM
getafewliv
getafewliv's Avatar
You must work for CSI with those crazy enhancing skills.
Old 08-06-14, 08:40 AM
PhiGam27
PhiGam27's Avatar
Ha. All I know how to do is resize and click the enhance button. I messed with every edit option photobucket has but not much made a difference. I will get good pictures tomorrow.
Old 08-06-14, 09:31 AM
codenko
codenko's Avatar
(10char)
Old 08-06-14, 01:13 PM
PhiGam27
PhiGam27's Avatar
One last attempt to get a better picture from what I have. If this doesn't work just check back tomorrow afternoon and I will have it actually installed with multiple pictures. This is straight from my phone on the app instead of sending to my email.
Old 08-06-14, 01:26 PM
metaleckz
metaleckz's Avatar
Looks good. But it would be cool if we can see it more
Old 08-07-14, 09:25 AM
PhiGam27
PhiGam27's Avatar
Got it all finished up today.
Attached Thumbnails Custom Grille-image-2335391725.jpg   Custom Grille-image-562507286.jpg   Custom Grille-image-2997454429.jpg   Custom Grille-image-3013617965.jpg
Old 08-07-14, 10:09 AM
MikeFoxx
MikeFoxx's Avatar
last pic looks good for what you did. should even out the horns and it would look cleaner (driver side)
Old 08-07-14, 12:22 PM
PhiGam27
PhiGam27's Avatar
I know. I think the problem is that in order to center them both I had to use a different hole on the passenger side. The holes are even but the passenger side one hits a lip so it stick out more and looks higher. I think I am going to grind down that lip and it should even out.
Old 08-07-14, 03:28 PM
MikeFoxx
MikeFoxx's Avatar
i haven't looked to much into it but i read a thread mentioning just drilling a new whole for the driver side. i'll find it.
not the one i was thinking of but another idea
https://www.clublexus.com/forums/is-...-pt-2-a-2.html
Old 08-07-14, 03:46 PM
Extreme Dimensions
Former Sponsor
Extreme Dimensions's Avatar
Looks Good!
You should get the emblem color matched for extra cleanliness.
Quick Reply: Custom Grille
