need help! noob here! polished lip scratch
Old 07-23-14, 01:45 PM
metaleckz
metaleckz's Avatar
Default need help! noob here! polished lip scratch
EDIT: new problem!!! so i sanded everything down including the inside lip
this is how shiny the outside part is
but the inside part, i cant make it shiny why?
Old 07-23-14, 01:53 PM
kumquatism
kumquatism's Avatar
I used blue magic metal polish with a red cone buffing pad to polish my wheels after sanding them
Old 07-27-14, 01:48 AM
metaleckz
metaleckz's Avatar
bump! new problem check 1st post
I think it has clear coat so i might need to buy paint remover
Old 07-27-14, 03:59 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I rennet long ago I borrowed my buddies Japanese wheels and I curbed one. I took it to the wheel repair shop and he confirmed it did have a clear coat on the lip. He removed it and poloshed as best he could. Wasn't as shiny but it looked pretty good.
Old 07-27-14, 02:40 PM
chi123
chi123's Avatar
The Work VS-XX comes polished but has an "annodized clearcoat" on it that apparently no local wheel repair places in my area can replicate. You need to treat it as you treat your car paint. Can't sand it with anything rougher than 1000 grit or it'll be really tough to remove the scratches. I had to re-lip my front Work VS-XX to clear my calipers and the new lips didn't have the clearcoat on them. It's a PAIN keeping them clean and shiny while the original finish just requires regular cleaning to look new.
Here's how mine looks when I sand it. Got to do it once a month to keep it looking good. You can tell yours still has the clear from your sanding marks. Uncleared lips come out dull with almost no sanding marks.
After buffing it out.
Old 07-27-14, 08:04 PM
metaleckz
metaleckz's Avatar
So you're telling me i have to sand it using 1000 grit? And when u mean buff it , is it the same as polishing it using lets say mothers mag and aluminum polish
Old 07-27-14, 11:19 PM
kentaro
kentaro's Avatar
https://www.clublexus.com/forums/aut...and-after.html
If you're sanding, you really have to even them out.
the lip should look evenly hazed instead of seeing scratch marks (= deeper marks from sanding).
then after you polish them they'll look mirror finish.
If you want even more shine, you can use aircraft remover to literally peel off the clear coat, then polish.
Hard to maintain but better results.
make sure you cover the face of the wheel if using aircraft remover. Really strong stuff
Old 07-28-14, 12:56 AM
metaleckz
metaleckz's Avatar
Really strong stuff
Old 07-28-14, 03:17 AM
metaleckz
metaleckz's Avatar
I wanna use a power tool to sand them. What do you guys recommend
Old 07-29-14, 01:40 AM
metaleckz
metaleckz's Avatar
bump! whats the fastest way to sand the outer lip?
i've been sanding one wheel for 2 days now and my finger tips are kinda bleeding (serious)
and no im not gonna pay 500-600 to have it done
help pls
Old 07-29-14, 12:37 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Those need professional help! Your faces are all chipped up too!
Old 07-29-14, 03:36 PM
metaleckz
metaleckz's Avatar
Well i stripped the face so its okay
i just want my lip polished without paying 600
Old 07-29-14, 04:13 PM
rawr2is250
rawr2is250's Avatar
Originally Posted by metaleckz
Really strong stuff
Did the aircraft remover do this?
Old 07-29-14, 07:43 PM
metaleckz
metaleckz's Avatar
Yeah i was trying to remove the clear coat. Didnt really help lol
Old 07-29-14, 10:46 PM
chi123
chi123's Avatar
Seeing how they look right now, I wouldn't even bother trying to fix them. Just have a wheel shop fix it since they have the right equipment to sand it, sand blast the faces, and powdercoat the faces. You'll be sanding for days just to get it to look like how it looked in the first picture with the light sanding marks.
But if you want to deal with it, you should really disassemble the wheels. Wetsand with 800, then 1000, then 1500, then 2000, and finally 3000 grit. You can skip 2000 or 3000 if you have a REALLY fast/good buffer but if you're using a drill or something, you need to go all the way to 3000 grit to get it looking good.
When you sand, wetsand and make sure dirt and stuff doesn't get caught in your sandpaper cause it'll scratch the lips. Keep sanding with each grit until you see little to no sanding marks. When you wipe it dry after wetsanding, it'll look like brushed aluminum. There's light sanding marks but it mainly looks very dull. I would guess you'll be sanding each wheel for about 3-5 hours lol.
Quick Reply: need help! noob here! polished lip scratch
