Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
IS350 Engine Cam-Gear problem finaly Fixed pt2
Thread Tools Search this Thread Display Modes
Old 07-11-14, 09:45 PM   #1
itsivan
Trader Score: (0)
itsivan's Avatar
Cool IS350 Engine Cam-Gear problem finaly Fixed pt2
Today i finally got my car back from Lexus. After 1 long month.
2 weeks to wait for a goodwill approval and 2 weeks for the parts to be delivered.
the engine wasn't giving out any power doesn't matter how much you floor the pedal would go like 5mph. and scary noises and clicking.
you can find my old thread when i got the problem here has video of how the car was acting up.
http://www.clublexus.com/forums/is-s...wap-is350.html
the codes i received when i got to Lexus were
p0010 camshaft position A actuator circuit Bank 1
p0016 camshaft position- camshaft position correlation bank 1 sensor A
p0020 camshaft position a actuator circuit bank 2
p0023 camshaft position B actuator circuit/open bank 2
p0102 mass airflow circuit low
p0113 air temperature circuit high input
p0335 crankshaft position sensor A circuit
p0340 camshaft position sensor circuit
p0348 camshaft position sensor A circuit high input bank 2
the car would not start even at Lexus they had to drain all the gas and put new one to start it up for further diagnostics.
when they took the engine apart all the cam gears were broken chipped and cracked.
(don't ask me how)
i was ready to buy a used engine but you guys told me to take it to Lexus i didn't want to go because i had no warranty and im the 3rd owned car has almost 100k miles.
lexus managed to good will all the parts for me all i had to pay was the labor.
i cant scan the labor performed sheet so ill shorten it
CAP, VALVE STEM
LOCK VALVE SPRING R
CAMSHAFT SUB-ASSY, N
GEAR ASSY, CAMSHAFT
GEAR ASSY, CAMSHAFT
GEAR ASSY, CAMSHAFT
BOLT W/WASHER
CHAIN SUB-ASSY NO.2
TENSIONER ASSY CHAI
TENSIONER ASSY CHAI
DAMPER,CHAIN VIBRAT
SPROCKET ASSY, IDLE
CHAIN SUB-ASSY NO.1
TENSIONER ASSY, CHAI
SLIPPER, CHAIN TENSI
DAMPER, CHAIN VIBRAT
BOLT, FLANGE
SPRING, COMPRESION
FIPG OIL PAN
REPLACEABLE ELEMENT
GASKET
OIL CHANGE
SUPERLONGLIFE COOL
FREON
My total labor charge was $2262
which is a lot better then buying a used engine and paying to get it installed and delivered
Lexus is still warrantying the work for 12 months.
thank you guys the people who helped me out on this and the people telling me to bring it to lexus lol
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
Thank You!!
itsivan is offline   Reply With Quote
Old 07-12-14, 12:23 PM   #2
sktn77a
Trader Score: (1)
sktn77a's Avatar
Could I ask who your case manager at Lexus Corporate was?
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2007 Lexus LS460
2005 Toyota Prius
1999 Lexus RX300 AWD
sktn77a is offline   Reply With Quote
Old 07-12-14, 12:35 PM   #3
rawr2is250
Trader Score: (0)
rawr2is250's Avatar
Wow that must have been scary with all of the cam gears broken. Glad everything worked out though!
rawr2is250 is offline   Reply With Quote
Old 07-12-14, 04:10 PM   #4
Gville350
Trader Score: (8)
Gville350's Avatar
So did they say what they thought caused this issue? Too much slack in the timing chain or timing tensioner slack?
Glad you got your car back!
__________________
'06 IS350 - 8.6468 @ 81.81MPH
Mods - SRI, BCRs, full GFX kit
Gville350 is offline   Reply With Quote
Old 07-12-14, 05:04 PM   #5
itsivan
Trader Score: (0)
itsivan's Avatar
Quote:
i have no idea sorry
Quote:
thank you
wish i knew bro i dont think even they knew they were looking at me like i drive crazy or something .
i would assume its something to do with the camgear recall thats why they payed all parts. i had no type of warranty what so ever.
__________________
Thank You!!
Old 07-12-14, 06:13 PM   #6
iRock
Trader Score: (10)
icekillah
Crazy. Never heard of that one before ��
__________________
iRock is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
step-by-step timing belt replacement LS430 jimdwright LS430 79 01-08-15 07:10 PM
I just purchased a 1996 LS400 with 218XXX Miles. Maintenance Advice? I have a list! BeLSNow111 LS400 28 02-04-14 10:02 AM
:( jbalian ES350 (2007 - 2012) 11 07-04-13 10:07 AM
Engine Diagnostic tools and pc tools (includes all trouble codes) Australian RX - First Generation 13 09-19-11 02:19 AM
Cold Start, Engine Noise, TSIB EG7027 Sparkplug GS - Third Generation 14 11-12-08 08:54 PM
Tags
460, bank, camgears, camshaft, circuit, engine, es350, gear, gs, high, input, is350, lexus, position, sensor
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
