Roadrover CL8018 8" Navigation IMPORTANT INFO
#31
Hello, I was using my road rover unit with the common issues, however, I had to put it out and then reinstall, and now I have this issue (https://www.youtube.com/watch?v=Hqvz...ature=youtu.be). I thought it was software, but I replaced my D2280 with the folder in this post and it was not fixed...any ideas to for look a solution?
Thanks in advance,
maguilarp
Thanks in advance,
maguilarp
I would remove the unit and make sure everything is plugged in correctly and that nothing else in the area got bumped loose.
If that doesn't fix it, reinstall your factory head unit and see if the problem persists.
#32
Boot Logo
Here is a boot logo I cooked up. It's for my CL8018 that's coming in, so I haven't tested it out.. Let me know if you like it!
Link to BMP: https://www.dropbox.com/s/f7tuxmd2o5...oQuoc.bmp?dl=0
#33
Reinstall
I have never seen that issue before. I doub tit has anything to do with the D2280 folder. Even without that, the climate controls and whatnot should still work correctly. I had completely messed up my unit and I could still use the climate controls and CD changer (but without the screen working).
#34
#38
Replacing Bluetooth Module
So I've also been reading that the bluetooth sound quality is terrible.
I just want to throw in the idea of replacing the bluetooth module inside the device...
As in desoldering the bluetooth board, and putting in a new module.
Has anyone tried this? erm... that you know of at least?
#40
#42
Thanks for the Info and guidance Getafewliv.
I got mine pretty much 100% now.
Only issues are:
Ipod loading is slow, faster if you pause the song.
24 time - Anybody figured out how to change it to 12hr time?
Only issues are:
#43
My current issues are:
-My clock adjusts itself by an hour randomly. (as well as the 24 hour instead of 12 hour)
-When my lights are on and I adjust the temperature, it adjusts the screen brightness.
-My USB flash drive doesn't load fast enough, so it loses the settings sometimes when I start the car. (thinking a faster USB flash drive may solve this.)
#44
Funny!
That's one of my issues too.... The clock randomly adjusting. Maybe set it an hour back and let it fall forward? Maybe its daylight savings?
Wish we had an engineer that could fix it for us.
#45
I've tried playing around with the clock settings in windows and adjusting the time zone.. but still... random time changes.
