what do i need to do to make this fit?
what do i need to do to make this fit without rubbing as much as possible
19X9.5 +22 front
19x11 + 25 rear
i have 09 is350
bc racing coilovers
everything else stock as far as suspension goes
i just want no wheel gap maybe 1 finger gap if i really need to raise it up a bit
what do i need?
19X9.5 +22 front
19x11 + 25 rear
i have 09 is350
bc racing coilovers
what do i need?
Fire Slayer
As far as camber kits go, get the Megan front upper A arms, rear upper arm, rear toe links (get the Figs ones if you can afford those, I had those and the quality is awesome). Sounds like that's about it with everything else you mentioned. I had to cut my linkers in certain areas also (after the tire did the initial cutting of the liner). You're going pretty wide up front and low offset. You may not be able to have a 1 finger gap but good luck with your figment.
19X9.5 +22 front
19x11 + 25 rear
i have 09 is350
bc racing coilovers
what do i need?
19X9.5 +22 front
19x11 + 25 rear
i have 09 is350
bc racing coilovers
what do i need?
I have 19x9.5 +21 in the front and only needed a roll and tab relocate......you don't need any extra suspension mods unless you just want to throw money at it......that 11 in the rear is a different story. I have 19x10 +27 so I can't help you there....big difference.
Oh and I have a 225/35 tire on the front.
Ownagespot
SC- 1st Gen (1992-2000)
31
12-21-12 06:46 PM
Hypebeast
12-09-11 07:01 AM
