Summer tires in rear and all season in front
Old 06-27-14, 03:11 PM
farmerchen
farmerchen's Avatar
Exclamation Summer tires in rear and all season in front
My 2010 IS250 got that ugly front left tire inner wear issue and i have to replace it.
The dealer will charge $350 each for original BS ER33 so i decided to move to other better solutions.
Now i prefer Continental Extreme contact DWS as I do not track cars and just daily commute between office and home. I just need a safe and comfortable feedback rather than hard corners.
Now the problem is rear tires are still ok and they are original BS ER33 summer tires, is there any big problem to just switch front tires to all season but keep the rear ones as summer tires ?
Old 06-27-14, 03:38 PM
darkdream
darkdream's Avatar
This will cause you to understeer more, which is safer than oversteering for the inexperienced, but less than ideal for spirited driving. This is better than visa versa in the wet since the front tires will most likely hydroplane before the rears, allowing you to feel it in the wheel early on. Unless your rear tires are really worn down when the rain comes, then that might be an issue.
Old 06-27-14, 04:15 PM
FSportIS
FSportIS's Avatar
+1 for darkdream.
It will understeer because the rear has better traction so the front is more likely to break loose first. This will only happen when you push the car hard at or over the limit of the tire traction.
On a daily driving, you should NOT have any problem. Don't track your car with the set up though.
Good choice on DWS, I have it on my IS250 daily driver, it is smooth, quiet, handle good and hopefully last long.
Old 06-28-14, 07:13 AM
idoke1
idoke1's Avatar
Honestly, the car will run fine but handling will be affected slightly. Best to change all 4 tires to continentals and sell the 2 rear turanzas.
Old 06-28-14, 09:14 AM
edgeucated
edgeucated's Avatar
You might feel a little under steer, but after a while you'll get used to it and your driving habits will change accordingly.
No big problems
Old 06-28-14, 09:33 AM
tex2670
tex2670's Avatar
No big problems
Yes--but how would it affect emergency handling?
Old 06-28-14, 10:32 AM
darkdream
darkdream's Avatar
No big problems
The car already understeers quite a bit even with f-sport sway bars and using the same front the rear tires.
Old 06-30-14, 11:43 AM
FSportIS
FSportIS's Avatar
Having the rear sway bar only (don't do front sway bar) will reduce the under-steering significantly.
yjy4321
04-03-17 07:39 PM
bowenn13
06-24-12 08:30 PM
BlueCrabby
Wheels, Tires & Brakes Forum
10-29-11 08:00 PM
WoofGS
GS - 1st Gen (1993-1997)
11-01-02 10:37 AM
VQT
SC- 1st Gen (1992-2000)
24
01-10-02 05:58 PM
Quick Reply: Summer tires in rear and all season in front
