245s on 06 is250
Old 06-18-14, 10:10 AM
mojamid
mojamid's Avatar
Default 245s on 06 is250
Tires need replacing.
A friend is selling a set of 4 but their all sized as 245s. I know currently the fronts are 225s and rear is 245s. Would 245s fit up front? I haven't found a definitive answer on this.
Old 06-18-14, 10:39 AM
getafewliv
getafewliv's Avatar
You will most likely have rubbing.
As much of a pain as it can be, find the proper size and save yourself future headaches.
I just went through replacing 4 perfectly good tires because they were 45 series.
Old 06-18-14, 10:53 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
What size are the tires? 245/45R17 or 245/??R17?
I run 245/40R17 all around on mine.
Jeff
Old 06-18-14, 11:14 AM
mojamid
mojamid's Avatar
They are 245/45r17
Guess I won't be buying them..
Old 06-18-14, 11:38 AM
WylieKylie
WylieKylie's Avatar
I run 245/40R17 on the front & 245/45R17 on the back. Stock ride heigh, no rubbing.
One thing Jeff forgot to mention is that he is running (IIRC) Bridgestone RE-11s on his car, so his 245s are as wide as many 255s.
Old 06-18-14, 11:46 AM
redspencer
OG Member
redspencer's Avatar
On my stock 18s, I'm using Michelin Pilot Super Sports and running 245/35R18 tires on the front and 255/40R18 tires on the back. My IS350 is also lowered with F-Sport Springs and Shocks.
Old 06-18-14, 03:08 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
This is true, I am running RE-11A's, and before that I was running Dunlop Z1 Star Specs, which are also wider than many 245's.
Jeff
Old 06-18-14, 04:22 PM
sktn77a
sktn77a's Avatar
You can usually get away with 235s on the 17x8" wheel but 245s are a no-no.
Old 06-18-14, 04:26 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Stock is 245 on a 17x8, so what do you mean?
You can absolutely "get away" with 245's on an 8-inch wheel, it's within the specifications for that size tire, it's not even a question.
Jeff
Jz39
IS F (2008-2014)
26
05-11-16 07:30 AM
0630562
05-16-15 04:12 PM
Trevstuh
North Texas Lexus Club
02-24-10 09:41 AM
mondizy22
12-30-08 06:59 PM
Quick Reply: 245s on 06 is250
