Uneven F sport exhaust....
Old 06-12-14, 05:45 AM
xanderES
xanderES's Avatar
Use a hose clamp from home depot and use it around the hangers. Added benefit from using them is that you can pull your exhaust up higher if you slam your car and itll keep your exhaust from bouncing when you hit a dip at speed.
Old 06-12-14, 11:14 AM
Sffd103
Fire Slayer
Sffd103's Avatar
The muffler shop that installed mine used a long bar to lower the one side to make it even. Came out perfect.
Old 06-21-14, 09:44 PM
deestyle28
deestyle28's Avatar
Thanks for the tip! Looks a lot better now. I should have got a smaller hose clamp but oh well. I'm just glad it's even.
Attached Thumbnails Uneven F sport exhaust....-img_7086.jpg   Uneven F sport exhaust....-img_1706.jpg
Old 06-22-14, 12:06 AM
Boy1109
Boy1109's Avatar
It cleaned up nicely, I'll definitely go this route if I have too once I install my exhaust.
Old 06-22-14, 01:07 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
thanks for the idea of the clamp. my passenger side needs to be brought up a little. great idea
Old 06-23-14, 05:06 AM
tmf2004
tmf2004's Avatar
do you remember what size clamp you used? 2'' maybe 3'' clamp? thanks
Old 06-23-14, 12:13 PM
Gville350
Gville350's Avatar
Cheap and effective right there! Worm clamps usually are not great for holding alot of load; but for a couple of bucks, why not!
Old 06-24-14, 09:28 AM
deestyle28
deestyle28's Avatar
Sorry tmf2004. I was lucky had one lying around and I didn't measure it. As you can see on my photo I had a lot of excess hose clamp after tightening so mine was pretty big. You can definitely go smaller. The hose clamp that I used was from my old intake pipe from my civic.
Depending on where you plan to put it on, just make sure the size you get is slightly bigger than the rubber hanger so you don't have excess hanging like I do. If you do, I'm pretty sure you can cut the excess off. Hope that helps.
Old 06-24-14, 09:29 AM
tmf2004
tmf2004's Avatar
thanks, picked up some 2.5'' clips this morning at Home Depot.. Trying this out tomoroow..
Old 06-24-14, 10:22 AM
FSportIS
FSportIS's Avatar
hahah you are creative with this simple and effective solution. Props to you sir!
Old 06-24-14, 02:08 PM
deestyle28
deestyle28's Avatar
Drove the car about 20 miles so far no issues with it coming loose. No rattling or anything. Will update again if I have any issues.
Old 06-24-14, 04:24 PM
tmf2004
tmf2004's Avatar
installed a clamp on the passenger side and worked perfectly... the driver side is not moving much so i might have to lower passenger side a bit or fit another avenue for the drivers side...
Old 06-25-14, 06:07 AM
tmf2004
tmf2004's Avatar
ended up using 2 clamps on the drivers side and now both sides are perfect.. didn't want to lower the passenger side as i like the look and less gap between the exhaust and bumper...
thanks again.. cheap easy fix and looks great
Old 06-25-14, 11:23 AM
deestyle28
deestyle28's Avatar
Glad it worked out. Any before and after pics?
Old 06-25-14, 02:25 PM
tmf2004
tmf2004's Avatar
before
after
Quick Reply: Uneven F sport exhaust....
