Rear end **click click click*
Old 06-09-14, 05:38 PM
getafewliv
getafewliv's Avatar
Default Rear end **click click click*
Now that I have been driving a lot with my windows down, I have been noticing a clicking sound coming from my rear end, mostly sounds like it is on the passenger side, but occasionally sounds more like the driver's side.
The noise is present generally when I am taking off from being stopped or coming to a stop. I mostly hear it when I leave from the house and pull out, I hear a **click click click**, sometimes only one click, sometimes 2 clicks... The easiest way to recreate the noise is if I drive forward a few feet, then backup a few feet, seems to make the noise the most when the load changes from front to back or vice versa.
Hoping for a simple fix, has anyone else had this issue before?
I should also mention that I recently lowered the car, on my own and in the driveway, so maybe I screwed something up? Not sure how long the noise has been present,
Old 06-09-14, 06:05 PM
Gville350
Gville350's Avatar
Seeing the recent suspension swap might have caused this new noise, I'd double-check all of the nuts/bolts to ensure everything is torqued. Also check the lug nuts.
Perhaps you can place a camera near or under the rear-end of the car so you can capture the sound and perhaps where it might be coming from.
GL!
Old 06-09-14, 08:20 PM
getafewliv
getafewliv's Avatar
Alright people... nothing to see here... move along...
Had a buddy move the car while I listened. Lug nuts needed to be torqued a bit more.
Old 06-10-14, 12:11 AM
Offspring
Offspring's Avatar
Buddy had a cts v, they were notorious for this. Had to get the lugs retorqued every month. Glad you figured it out !
Old 06-10-14, 01:09 PM
Gville350
Gville350's Avatar
You are welcome.
Old 06-10-14, 01:39 PM
getafewliv
getafewliv's Avatar
Thanks guys.
It's always nice when it is a simple solution with an easy fix.
Old 06-10-14, 03:24 PM
FSportIS
FSportIS's Avatar
Thanks for sharing too. Now, the community knows how to fix this when it happens
Good suggestion Gville350.
Old 06-10-14, 06:48 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Happened to my car too before I sold it. The guy at the shop didn't torque down the lugs also.
Old 06-11-14, 01:49 PM
Gville350
Gville350's Avatar
^This is the reason why I always check my lugs when I get home from any tire shop. I have to say though, I've NEVER had any issues with loose lugs or incorrect torque coming from Discount Tire.
CT 200h Model (2011-2017)
08-07-12 02:49 PM
tommy152
05-03-11 04:54 PM
dannygjatt
05-29-10 02:13 AM
daudbros
11-28-07 10:35 AM
lefty75
Suspension and Brakes
04-04-07 10:14 PM
Quick Reply: Rear end **click click click*
