what gas do you use?
Old 06-01-14, 08:58 AM
dsigs83
dsigs83's Avatar
Originally Posted by Zinda
I don't know why people even ask this...back in the day we argued this to death. And the concensus was always go premium...Why do people insist on ignoring recommendations from the maker of the car?
because someone recommends something doesnt necessarily mean its the right thing to do. BUT in this instance, after i put the octane booster in, the car ran so smooth i was absolutely shocked how a few octane can make such a difference. i will 100% be using 93 from now on.
i screwed that one up!!
Old 06-01-14, 10:05 AM
Zinda
Zinda's Avatar
REALLY? So then why don't you ignore the car manufacturers maintenance schedule since you know better? In fact, throw your manual away...
Old 06-01-14, 10:08 AM
dsigs83
dsigs83's Avatar
we can be smart asses all we want but the fact is, they recommend changing the oil every 3000 miles but you really wanna argue doing it 500 miles after will REALLY affect the car in a negative light? i dont.
regardless, i realized and admit i was wrong about the gas, lets start an argument online about it.
Old 06-01-14, 10:42 AM
nosurprise
nosurprise's Avatar
Who recommends changing oil every 3,000 miles other than the oil-changing shops? The recommendation from the manual is 5,000 miles. Will it hurt if you change the oil every 5,500 miles? I'm 100% sure it won't. But the gas and oil are for different purposes that I assume Lexus has different tolerances for them being out of recommended range before having negative effect on the car. Like others have already said, it's been argue to death, but the conclusion (I got) is that most likely you can run regular without damage but lower performance and smoothness.
Old 06-01-14, 11:56 AM
frmUkraine
frmUkraine's Avatar
Originally Posted by CNStars17
I run on E-30 to E-50 blends of ethanol. If only E85 is available at the pump I blend it with 91 in my tank. The higher level ethanol blends are cheaper & higher octane. Pure ethanol is 113 octane; so E-30 to E-50 will run around 94 oc
The IS has a compression ratio of 12 to 1, very high, so it takes advantage of the higher octane.
For how long do you use ethanol in your car? And how many miles do you drive annually? I'm asking because there is phobias of ethanol, because it is hygroscopic and may damage metal parts of fuel system. And what is the difference between mileage on premium gas and ethanol on your regular trips? Thank you!
Old 06-02-14, 11:18 AM
FSportIS
FSportIS's Avatar
Be a man to save 1 dollar
Originally Posted by GiantsFan
Oh god, another one of these threads ... Every year without fail lol.
Premium. Its what is says next to the gas cap. Stop cheaping out on 20 freaking cents per gallon.
Brabusx2
05-02-12 11:43 AM
Lexus999
IS F (2008-2014)
45
02-01-10 11:37 AM
pharrside
CL of Hawaii
14
04-20-09 12:41 AM
TommyT
06-21-08 07:34 PM
JohnsRX
RX - 1st Gen (1999-2003)
06-08-04 07:38 AM
Quick Reply: what gas do you use?
