P0051 cel
P0051 cel
Does anyone know how to replace the sensor to clear this code? I replaced the spark plugs and a week later this code appears. Thanks
H02S Heater control circuit low bank 2 sensor 1
It's saying you have a bad a/f sensor. Do this first reset the ecu to clear your code. Do a search and you see how to do it. Then wait to see if it comes back on. If it does replacing your A/F sensor. Or double check your work after you installed the plug to make sure nothing wrong.
I found this thread if anyone knows the part number
https://www.clublexus.com/forums/is-...placement.html
thanks I see the sensor on the header driver side but I don't see the connector. When I put it on a lift will the connector be accessible from below? Also is the driver side left or right? Can I unplug the sensor then start the car and see if its the correct sensor I unplugged?
I replaced the o2 sensor and what a PIA that was. I didn't know they make a o2 sensor socket until I went to autozone. I don't have a lift so it was difficult to remove the connector. I took the intake manifold off so I can reach the back to where the connector is at. The CEL cleared and I passed inspection. I also found this thread after I was done
https://www.clublexus.com/forums/is-...ensor-2-a.html
