Custom painted headlights
Old 05-15-14, 01:10 PM
Joelseff
Joelseff's Avatar
Originally Posted by PetesSweet
LED angel eyes on low beams only and they'll be DRLs, so pretty much like BMW or any other car with aftermarket rings, helps the car stand out more aggressive
Are they wired to the DRLs or a separate switch? Very nice by the way!
Old 05-15-14, 02:39 PM
pmanliu
pmanliu's Avatar
We bought a lense restore kit you can buy online, requires a ton of buffing and elbow grease but the results are night and day
Yeah, i did this before just using varying grits of sandpaper. However from experience if you dont clear coat it, it will yellow a lot faster (within a few months). Was just wondering if you had a workaround for this
Old 05-15-14, 03:32 PM
FSportIS
FSportIS's Avatar
Do you have pictures of the set up with the car with DRL on??
To prevent yellowing, apply 3M clear bra and top it off with Opticoat. I did that and the headlight looks brand new after more than 2 years.
Old 05-16-14, 12:07 AM
PetesSweet
PetesSweet's Avatar
Default Picture update!
Total cost for the painted housings, Angel eyes, tinting the turn signal reflectors, and doing a lense restore was only 475bucks if anyone is interested in shipping your lights to Morbid Customs they can do it all in a few days
Old 05-16-14, 12:09 AM
PetesSweet
PetesSweet's Avatar
DRL in the hibeams was direct plug in to the Angel eyes so anytime that stupid bulb in the hi beams would be on, instead the Halos are on
Old 05-16-14, 12:10 AM
PetesSweet
PetesSweet's Avatar
More pictures
Old 05-16-14, 12:11 AM
PetesSweet
PetesSweet's Avatar
Here's some pictures with my RGB and low beams on
Old 05-16-14, 12:12 AM
PetesSweet
PetesSweet's Avatar
Picture of seeing the blacked out housings
Old 05-16-14, 12:14 AM
PetesSweet
PetesSweet's Avatar
Paint I used was 3 cans of the Duplicolor rattle can that's for Toyota make cars that I picked up at Autozone, paint blends together like OEM
Old 05-16-14, 05:31 AM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
Not to get too far off track, but all headlights come from the factory with UV protection on them, but this protection will wear away overtime and the plastic will oxidize. This oxidation must be removed (via the restoration kits or like products) to restore clarity back to the lenses, but then what most people don't realize is that they need to either continuously add UV protection with some sort of wax or sealant (ie every month or so) or they need to invest in a new permanent layer of protection like Optimum Opti-Lens. Without a good layer of protection, oxidation will return very quickly, as you mentioned.
... sorry to go off topic
Old 05-16-14, 07:25 AM
skoota500
skoota500's Avatar
Where did you get the halos?
Old 05-16-14, 08:03 AM
istarzan
istarzan's Avatar
What lense restore kit did you buy?
Old 05-16-14, 08:12 AM
zmcgovern4
zmcgovern4's Avatar
This is a good basic kit - Meguiar's Heavy Duty Headlight Restoration Kit
Old 05-16-14, 09:40 AM
Joelseff
Joelseff's Avatar
Nice. Do the high beams still work?
Old 05-16-14, 10:14 AM
PetesSweet
PetesSweet's Avatar
The hi beams are now Stage 2 LEDs, since when you engage the hibeam that the low beam stays on I thought what's the point of the hi beam anyways, my stage 2 RGB led do just fine
Quick Reply: Custom painted headlights
