Tire pressure sensor for 245-35-20
Old 05-05-14, 11:53 PM
Monique023
Monique023's Avatar
Default Tire pressure sensor for 245-35-20
Team,
Can I use the stock tire pressure sensor for a 245-35-20 tire? If not where can get ones for my 07 IS250 RWD?
Old 05-06-14, 06:13 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Yes you can. Only some JDM wheels require a strap to hood them down.
Where is that tire being mounted, front or rear?
Old 05-06-14, 10:39 AM
Monique023
Monique023's Avatar
Am installing all 4 tires (1 front and 2 rear) Hankook V12 with 245-35-20. The rim is 7.5 therefore am going to have to use spaces at the rear. But I don't want to loose the Tire pressure sensor functionality. How can they be installed? Is there a Youtube video or guide? I want to use OEM tire pressure sensors that are actually on my 18" stock wheels.
Old 05-06-14, 11:03 AM
WylieKylie
WylieKylie's Avatar
TPMS sensors are installed the same on pretty much every wheel there is, unless you have access to a tire changer they will be installed by your tire shop along with the tires.
That is a pretty big tire for the front end of the car.
Old 05-06-14, 05:31 PM
mandyfig
mandyfig's Avatar
Originally Posted by Monique023
Team,
Are you referring to the TPMS sensor?
Old 05-07-14, 06:21 AM
Monique023
Monique023's Avatar
MANDYFIG: yes am referring to the TPMS sensor.
WYLIEKYLIE: they installed the tire and I was able to rotate the front tires without issues. Am attaching a pic for you to see how it looks.
Kuhn
11-27-17 10:43 AM
ElMatadoro
11-11-13 04:32 PM
LIMS407
01-24-11 07:07 PM
inecstaz
12-19-07 01:15 AM
TXFM
02-09-07 06:46 AM
Quick Reply: Tire pressure sensor for 245-35-20
