Changing speedometer orange flashing at 80mph
Is there a way of changing the flashing orange on the speedometer from 80mph to 100? How about the RPM? Could there be only orange because my friend had a blue needle.
This is not part of LPS so no need to go to the dealer. The switch is on the panel to the left of the steering wheel. This switch also use for turning the AFS ON/OFF (if equipped) and reset/recalibrate the TPMS along with the Tach setting.
Very simple procedures! Read the owner manual.
Super Moderator
Yes, this was my thoughts as well!
By the way, I know for a fact you can't change this with menu where you can turn AFS off. I use that menu often and have never seen a place where I can set the speed in there.
Turn you car On but with the engine off. Scroll through this switch [<O>] and find "Speed Indicator". Turn it off and then back on. It will ask you to SET. Use the arrow buttons to move up or down. Once you have your desired speed, press ON/OFF button to set.
