Air filter
If it isnt in "recirculate mode" the plastic piece you need to slide out of the way to access the air filter is "locked" in place. If you force it open you will break the mechanism that opens/closes it based on your climate control settings.
I have tested F Sport intake system on my IS250 over several months now and I gain roughly 1 mpg plus an aggressive sound @3000k RPM +. Not to mentioned it has 5 HP gain which seems small but also the cheapest per HP gain we can have in this car.
Also, I only have to clean the f sport filter every 30k miles or so without any replacement.
Also, I want to clarify that there are 2 filters being discussed here:
1. Engine filter in the engine base. This can be removed when the engine is off. It doesn't matter if it is on circulation mode or not. F Sport filter is put in here and since it is high flow, this creates more efficient air flow than the paper OEM one.
2. Cabin air-filter inside the cabin air box in which removal will require "circulation mode". There is NO F Sport cabin air-filter here.
Ok so I think I may have fudged something up. I know I said I changed my air filter with no problems, but I don't know. I feel hot air coming through my vents when it is on recirc. Also, there is a chicken farm we drive by when we go home to visit......when we drive by it we normally put it on recirculation so we can't smell it. Well when we do it in my car the smell still comes through.....and not faint either.
I never paid attention this could have always been like this and I never really noticed, but I can't help but wonder if I did something.
Are these the kinds of things that would happen from changing the filter in the wrong mode? If not why is my recirculation mode basically also my fresh air mode? lol
If it was NOT in recirculation mode then you would've had to break the plastic piece to get into the cabin air filter. So then resulting it would not ever close to bring in fresh air from the outside and would be recirculating air all the time bc of the door that closes when its not in recirculation mode.
