Rim and tire question
Old 04-24-14, 12:38 PM
Ants350
Ants350's Avatar
Hi I have 2007 Lexus is250 rwd. I wanna get new rims my front tires are 225 40 18 92w. Rears are 255 40 18 99w. Rear tires are wider. Will the same size rims fit all around or do I need separate size for rears. Thanks just wanna make sure.
Old 04-24-14, 12:52 PM
lysis250
lysis250's Avatar
If I were you just get staggered if the wheels you like are offered in a staggered set up. I've seen a square set up on the tire sizes you have listed and I was gonna do that with some LFA Reps, but I ended up just getting staggered wheels.
Old 04-24-14, 01:51 PM
Ants350
Ants350's Avatar
Also how do I find out the offset sizes for my car. Thanks
Old 04-24-14, 03:16 PM
FSportIS
FSportIS's Avatar
OEM specs are:
18 x 8.0 45 MM front
18 x 8.5 50 MM rear
Old 04-24-14, 05:02 PM
Ants350
Ants350's Avatar
Hey fsportIs so when I buy rims I'm buying 2 different sizes? Thanks again.
Old 04-24-14, 05:50 PM
lysis250
lysis250's Avatar
Yes, when buying wheels there is a lot to take into consideration. The rears should be wider then fronts.
Old 04-24-14, 07:11 PM
jdmSW20
jdmSW20's Avatar
you can run a square setup even on RWD but just make sure you have all your specs and math done. but these cars run staggered wheels from the factory on RWD models
Old 04-25-14, 02:03 AM
Ants350
Ants350's Avatar
Ok cool thanks a lot for the info.
Ants350
05-07-14 06:56 PM
jminor
10-30-13 10:25 AM
ev0lution1
06-01-13 02:32 PM
Belmont
03-28-06 07:11 PM
lex430
05-30-01 09:57 AM
Quick Reply: Rim and tire question
