rear defroster + FM radio = static
Old 04-17-14, 11:47 PM
LADavidGS
LADavidGS's Avatar
Default rear defroster + FM radio = static
My friend's 07 Is250 with navi is having an issue where if you select rear defroster the only the FM receptions becomes static. She has tinted windows but never encountered such problem. Can anyone recommend to fix this problem?
Old 04-18-14, 05:13 AM
DKIS350
DKIS350's Avatar
I have seen this before on other cars and it could be a bad ground. Check to make sure one of the defroster connections hasnt been bumped or broken and there is no damage to the grid. I did see once where in the dealership we needed to replace the rear glass of a camry for this (this was on a brand new one after it came of the truck).
Old 04-18-14, 10:56 AM
LADavidGS
LADavidGS's Avatar
Thanks DKIS350, can you or anyone else tell me which one is defroster connectors?
Old 04-18-14, 07:45 PM
racsos222
racsos222's Avatar
i also have this. I bought my car used it is also a 07. The previous owner had the rear windshield replaced under factory warranty and it still happens the dealer cleaned the rear windshield for me and it got a bit better. They said it had corrosion?
Old 04-18-14, 11:13 PM
LADavidGS
LADavidGS's Avatar
how bad was corrosion?
Lexitegra
12-28-15 03:50 PM
kenEs350
ES - 5th Gen (2007-2012)
03-26-15 06:09 AM
lexuslivin
08-22-09 07:41 AM
jetman
11-15-07 06:18 PM
Quick Reply: rear defroster + FM radio = static
