How do I determine if I have AFS?
Old 04-13-14, 08:33 AM
babaliont
babaliont's Avatar
Default How do I determine if I have AFS?
My used 2012 IS 350 has headlight washers. I know that they are auto-leveling because I see the beam go up and down when I start the car, but how do I know if I also have AFS (adaptive front lighting system)? Is there some setting inside the car that tells me I have those?
Old 04-13-14, 08:35 AM
laobo979
laobo979's Avatar
With the new led head lamp you don't have afs.
Old 04-13-14, 09:01 AM
babaliont
babaliont's Avatar
AFS sounds like a cool feature. Why is it not available with the led headlamps? Do led headlamps make AFS redundant or technically impossible in some way?
Old 04-13-14, 09:05 AM
jdm_altzza
jdm_altzza's Avatar
Really not sure why this feature was disabled. I had taken both sets apart in comparison & thought about swapping some inner parts;however they are different in diameter and will require alot of modification.
Old 04-13-14, 09:59 AM
tex2670
tex2670's Avatar
They got rid of it in whatever MY that the LEDs debuted--I'm sure it was cost cutting. Before that, if you have HIDs, you also have AFS--it has nothing to do with headlight washers, which are a stand alone option. If you don't have it, you aren't missing much.
Key way to tell is the button to the left of the steering wheel used to adjust the speedo and tach rings that looks like this [<O>], and scroll thru the settings. If you have AFS, one of the settings is AFS On/Off.
Old 04-13-14, 12:00 PM
Gville350
Gville350's Avatar
Having the AFS headlamps on my '06 helped save me from hitting dear crossing the road Super Bowl Sunday evening 2 yrs ago. I say they're worth it!
Old 04-14-14, 12:40 AM
istarzan
istarzan's Avatar
Because of the leds, there was no room left for afs so they deleted it. I too like my afs which is why I'm not updating to leds.
happy1977
RC - 1st Gen (2015-present)
02-19-19 09:45 PM
Lexb4sex
03-13-16 04:32 PM
AK-47
Lighting
03-20-15 10:38 AM
Mors
Hybrid Technology
12-17-13 06:12 AM
HERBos
05-20-11 12:05 PM
Quick Reply: How do I determine if I have AFS?
