Help Mirrortapping Valentine One 07 IS250
Old 03-31-14, 06:47 PM
TheVille
TheVille's Avatar
Default Help Mirrortapping Valentine One 07 IS250
Just got my valentine one with blendmount and mirrortap.
Need help with the wiring, which goes where?? Please see picture!!!
Thanks!!
Cole
Old 03-31-14, 06:59 PM
TPIS350AWD
TPIS350AWD's Avatar
Check this thread:
https://www.clublexus.com/forums/is-...full-post.html
Old 03-31-14, 07:03 PM
TheVille
TheVille's Avatar
I've read through it but it seems it's only for the phone cord, not mirrortap cord
Old 03-31-14, 07:06 PM
pheonix72
pheonix72's Avatar
Since your car is 2007, I believe the switch 12V power source is the ORANGE Wire for Positive and the BLUE is ground. I am not responsible for this so please use a Volt Meter to verify.
Old 03-31-14, 07:11 PM
itstoyota
itstoyota's Avatar
You can try, Power to red pin and Ground to green pin.
Old 03-31-14, 09:01 PM
TheVille
TheVille's Avatar
I think i found it on the one thread, + Red to Orange wire, and - Black to blue.
Ill keep everyone updated.
Old 03-31-14, 09:49 PM
pheonix72
pheonix72's Avatar
Orange and Blue connection for switch power, which is a prefer way to hook up your V1.
Old 04-01-14, 03:59 AM
d0ok13
d0ok13's Avatar
My mirror harness only had three wires. I don't remember what the colors were. GL
Old 04-01-14, 05:45 AM
saxqtzk
saxqtzk's Avatar
I just did this yesterday. Car side of harness it's white/black and black. Mirror side is blue and orange
Old 09-11-14, 10:59 AM
JasonZ-YA
JasonZ-YA's Avatar
Black/white + positive
Black - negative/ground
ya, I used the car side simply because the car side of the harness had wider access to pin in the hardwired pin at the end of the pigtail wire i made.
I went to radio shack and purchased D9 sub pin connector p/n 276-1427, cost was $2.99:
From there i simply stripped the wire from a spare escort cable i had, the pig tail squiggle cord....uses a light tester and verified which wire was postive and which was negative and simply soldered the wires to the pins.
Car side connector is the side of the connector closes to the headliner - with the pins that most of the online kits come with and the pins i used from radio shack wont fit on the orange/blue side of the connector.
The car side has a much wider access of the wire and pushing the pins in was simple and held tight with no issue.
Car side:
From there, i just put the plastic harness cover back on and everything came out looking very clean looking.
My friend was happy to get this installed........his 2nd gen IS250 -2006.
-J
basacowan
RC F (2015-present)
04-24-18 08:01 AM
socaligs
01-09-17 09:02 PM
rbetts1093
Hybrid Technology
03-06-16 06:37 AM
powderbrak
ES - 6th Gen (2013-2018)
01-15-14 06:40 AM
costanza
04-18-13 10:01 AM
Quick Reply: Help Mirrortapping Valentine One 07 IS250
