obd2 read p2195 and p2172 ? need help
03-25-14, 04:45 PM
Ok i got my car scanned and it showed up p2195 and p2172 . Has anyone ever got these two code before . engine light , check vsc and slip indicator ( traction light )
03-25-14, 04:58 PM
I had P2195 around 2-3 months ago and I just erased the code. I've been driving ever since without any issues and the car is running perfectly fine.
03-25-14, 05:00 PM
did u unplug the battery ?
03-25-14, 05:48 PM
No, I used the scanner to erase it.
03-25-14, 06:55 PM
P2195 O2 Sensor Signal Biased/Stuck Lean (Bank 1 Sensor 1) Code
P2172 Throttle Actuator Ctrl Sys-Sudden High Airflow Detected
03-25-14, 08:13 PM
Ive seen the stuck lean code, bad sensor but never the air flow one, make sure your intake tube is tight
03-26-14, 08:22 AM
also clean the mass air flow sensor while your tightening things up... mine came up during the 02 code a couple times...
trichmont
ES - 5th Gen (2007-2012)
09-10-12 07:33 PM
Hatchman
RX - 1st Gen (1999-2003)
07-14-10 04:13 AM
esucaris1
07-23-07 10:03 PM
squeekyM
09-26-06 07:36 AM
steviej
Maintenance
06-08-05 03:15 AM
