Replica 2011-2012 LED headlights (Alibaba)
Old 03-17-15, 01:26 AM
  #181
ISland350
ISland350's Avatar
After the horror stories were still trying to buy these? c'mon guys i understand OEM is expensive but from what ive seen so far youre basically throwing ur money in the trash with these.
Old 04-04-15, 10:31 PM
  #182
Pumaking82
Pumaking82's Avatar
Default just installed
Just finished installing, now the AFS Off light keeps blinking, did anyone else encounter this issue? Did i do something wrong? Followed the video instructions from Spec D,
Old 04-05-15, 01:50 AM
  #183
GiantsFan
GiantsFan's Avatar
Of course your AFS light will blink. The eBay lights don't have it!!!
If you have OEM HID this is a HUGE downgrade.
Old 04-05-15, 09:57 AM
  #184
trippy
trippy's Avatar
oh wow thanks for this I will not spend my money
Old 04-05-15, 12:16 PM
  #185
Pumaking82
Pumaking82's Avatar
Default thanks
Figured, tried to disable AFS through the dash options but it doesn't allow it. Well it needed headlights, old headlights had water damage, foggy and one was giving us major issues. Went with our best "economical" option for the time being.
Old 04-05-15, 10:22 PM
  #186
SeanIS350
SeanIS350's Avatar
Even with the OEM ones the AFS light will flash if you had AFS on your originals and installed the OEM led headlights.
Old 04-06-15, 04:11 AM
  #187
jediroger
jediroger's Avatar
Has anyone seen this set yet? It looks like a newer version of the third party LED headlights:
http://www.ebay.com/itm/2006-2007-2008-Lexus-IS250-AWD-RWD-LED-Daytime-Running-Light-Projector-Headlight-/191551252520?&_trksid=p2056016.l4276
Old 04-06-15, 05:11 AM
  #188
B16da9
B16da9's Avatar
looks like the same crapy lights just painted black.
Old 04-08-15, 11:52 PM
  #189
nosurprise
nosurprise's Avatar
Why can't they make one that's half-way decent? I mean add a few hundred dollars and make it better; I'm sure it will sell more (like the RoadRover nav quality -- while the software kinda suck, the hardware and parts are actually pretty good).
Old 08-11-15, 07:45 AM
  #190
ClayBiggs
ClayBiggs's Avatar
Default Projector Headlight AFS??
Hey So did your OEM have the AFS where the lights turn side to side when turning?? If so does your dash now have an AFS light on all the time due to the new lights not having that option?
Old 08-11-15, 11:20 AM
  #191
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default ...........................
Warning to everyone trying to look cool with these or even OEM LED headlights.
If you have AFS as an option on your car the AFS light will drive you nuts because NONE of the led type headlights including factory supports AFS!!!
Why sacrifice AFS to look cool? AFS has a great function.
You will have to remove the AFS warning bulbs.
Old 08-12-15, 04:45 PM
  #192
SeanIS350
SeanIS350's Avatar
You don't have to remove the AFS light, you can just cover it up. DIY link below:
https://www.clublexus.com/forums/is-...mp-owners.html
Old 08-12-15, 04:49 PM
  #193
jdubbsISF
jdubbsISF's Avatar
Relax and just pull the fuse. Takes 2 seconds, I did it
Old 04-24-17, 02:07 PM
  #194
Sconnie
Sconnie's Avatar
So no fuse no problems? No more dash light?
Old 04-24-17, 03:09 PM
  #195
MikeyK02
MikeyK02's Avatar
Correct you just lose afs which is pretty much the most useless thing ever put on a car
Quick Reply: Replica 2011-2012 LED headlights (Alibaba)
