AFS Lever Sensor Arm snapped in half.
I took my car to a mechanic due to the AFS light indicating that it's OFF. It seems that the AFS Lever Sensor Arm has snapped in half
So I've attached the damage below. Would anyone know where I can get this part?
Lexus IS250 AWD 2007
Thank you in advance.
local junk yard...
Can you maybe make one?
2 of these
http://www.mcmaster.com/#6275k54/=r7nk55
1 of these and a hacksaw
http://www.mcmaster.com/#99067a248/=r7nmta
note: these are 8mm ball joints in the link above. you may need to go up to 10mm or down to 6mm depending how big this lever is. It is a little hard to tell in your picture.
Good Luck!
2 of these
Good Luck!
Wow, so expensive
But thank you for pointing me towards the right part number. Now I can know how to call the part!
This might actually work! I will definitely will try this if gluing does not help. Thank you so much.
2 of these
Good Luck!
2 of these
Good Luck!
