CEL after eating a pothole
06 IS350 RWD
2 weeks ago i ate a massive pothole going 70 mph on the highway, soon after which my check engine light came on. I pulled the negative terminal to reset everything and the code went away, only to return after 30 -50 miles of driving. Ive done this about 3 times.
Today i got the codes pulled . Anyone else experience something similar, possibly have a fix for this ?
Regards.
P0441
Definition: EVAP system incorrect purge flow.
Probably Cause: Block Vapor Canister, Vent Solenoid Malfunction, Purge Solenoid Malfunction.
P0455
Definition: EVAP System Gross Leak Detected
Probable Cause: Failed Vent Solenoid, Loose/Missing Gas Cap, Purge Solenoid Malfunction
Regards.
P0441
P0455
My car was at the dealership due to excessive oil consumption. They did a compression test leak down test and other tests. Any chance they left something's unplugged ? The cel did come on on my way home from the dealership.
Just do what everyone else does, take it back to them and have them fix it. Chances are they could have left a small vacuum line unplugged or a sensor unplugged. They may have had to pull the intake manifold off to get to the plugs to get the testing equipment into them. (I know it's a 350 and you can work around it to change plugs but the testers might not have fit.)
I'd take it back to them to have it checked out. The sooner the better.
I had the same error codes a few weeks ago on my IS250. I replaced the gas cap and that didn't fix it. I had a leak test and nothing showed up. I finally replaced my purge valve located in the engine bay and that resolved it. I hope that helps.
calvin2376
12-19-14 01:18 AM
ChanceM40
RX - 1st Gen (1999-2003)
11-23-14 06:36 AM
