IS250 steering wheel loose on left turns
Old 02-28-14, 12:46 AM
mastaaku
mastaaku's Avatar
Default IS250 steering wheel loose on left turns
Hey guys,
So on my 07 IS250, I noticed my steering wheel isn't completely straight when I drive. It pulls to the right. When I make a right turn the steering wheel tightness feels normal. When I make a left turn it feels a bit loose and easier to turn. Recently had all my tires replaced and alignment done. The problem still continued. Had alignment checked from another place and they say it is perfectly fine. Any ideas on what the problem might be?
Old 02-28-14, 12:16 PM
Gville350
Gville350's Avatar
The first part of your issue with the pulling to the right seems to be a "common" Lexus issue (even after an alignment; happened to me and I even created a thread about it.)
Now, about the looseness; I'd remove the front left wheel and check ALL of the bushings and steering linkage. The rack is electric, not hydro...if you didn't know.
GL!
Old 03-07-14, 07:10 PM
bruins678
bruins678's Avatar
This week my steering became noticeably lighter all of a sudden. I'm sure of it, because I take the same tight turns through my work parking garage day in and day out.
I figured since our steering stiffness is electronically controlled, it couldn't hurt to disconnect my battery for awhile and hopefully reset the steering ECU.,,I tried it and all I know is that my steering stiffness was back to normal levels on the first drive after reconnecting my battery and since then. You might want to give it a shot for your problem as well.
Has anyone else verified whether or not disconnecting a battery can reset the steering ECU and affect steering stiffness or calibration? It seems to have worked for me, or it's super high coincidence.
Old 03-07-14, 07:33 PM
darkdream
darkdream's Avatar
I noticed when my battery is almost completely dead my steering improved because there was no power steering, but the downside was my tachometer flickered on and off.
Old 03-08-14, 10:34 AM
gardenkhs
gardenkhs's Avatar
I have same problem now.
After i change wheels, tires and alignment, my steering is lighter than before.
What do i need to do??
Any recommendation??
Old 03-11-14, 05:45 AM
mastaaku
mastaaku's Avatar
I will try disconnecting the battery today and let you guys know if it fixes anything.
Old 03-11-14, 08:35 AM
idoke1
idoke1's Avatar
^^just be sure to disconnect the battery and wait and couple of mins before reconnecting the battery.
Old 04-16-15, 07:00 AM
jonathanz
jonathanz's Avatar
how's everyone doing with this? indeed i feel turn left is easier than turn right.
Old 04-22-18, 03:49 PM
Timestream
Timestream's Avatar
Default Same problem
New to this so go easy, just bought a 2009 is 250 and i have the same problem left turn is MUCH easier than right and it is driving me creazy. I did the battery trick no dice and my alignment was done to PLZ help
seanmwple
05-19-18 09:06 PM
reyrey127
GS F (2016-present)
12-29-17 05:17 PM
Najeeh
09-30-15 11:11 AM
newpuy
05-11-10 08:00 AM
cnstarz
12
01-12-08 12:22 PM
Quick Reply: IS250 steering wheel loose on left turns
