wheel spec opinion?
Old 02-14-14, 01:52 PM
Galvez
Galvez's Avatar
Default wheel spec opinion?
I have been searching for some pics to see how this setup will work. I plan on purchasing some wheels that are 19x9.5+25 and 19x11+25. Now I know that spec in the rear is going to be a pain to fit, so I was thinking of getting a 9.5+12 in the rear to make it a bit more manageable. My question is will this look odd? If anyone can help out and give their opinion. Does anyone have a pic of a setup similar to this or at least the rear wheel spec? Thanks in advance
Old 02-14-14, 05:42 PM
jdmSW20
jdmSW20's Avatar
it wont look odd, that setup is pretty common really, as far as 9.5/11
just make sure your tire spec is just right so you have the clearance, and get your fenders pulled/rolled and you will be fine. youll need rear camber arms for that rear spec though, im 100% positive. Because im an 11 rear and had to run about -4.5 degrees of camber
Old 02-14-14, 05:52 PM
heyarms
heyarms's Avatar
My rears (and fronts) are more aggressive than that. Can't really say what they are but you'll need camber arms for the rear and a roll/pull at least. Depends on a lot
Old 02-14-14, 06:12 PM
jdmSW20
jdmSW20's Avatar
to the OP like stated above youll need arms and a pull at extreme minimum. but this is an 19x11 rear, and -4.5 degrees camber... so good examples of that setup on air like heyarms, and mine static
and just have a standard roll in the rear, nothing crazy at all
Old 02-14-14, 06:15 PM
Silec
Silec's Avatar
front fenders will need to be rolled as well and the bumper tabs will need to be relocated if you want to go low. Camber kit is a must in the rear but not the front.
here's my car, rear is 19x10.5+18 with -4.5 degrees of camber aired out.
Old 02-14-14, 06:30 PM
Silec
Silec's Avatar
here's a better picture
Old 02-14-14, 11:12 PM
Galvez
Galvez's Avatar
WOW! ok im convinced. what tire size you guys running in the rear 245?
Old 02-15-14, 12:04 AM
jdmSW20
jdmSW20's Avatar
im running a 265/30 on my rears. its a lil wider but not as tall as a 245/35 wouldve been
Letsstance
Suspension and Brakes
03-28-15 12:37 AM
ktb
IS F (2008-2014)
03-04-13 02:27 PM
Woowee
01-04-13 02:34 PM
bowflex21
04-22-11 12:12 PM
sojah
10-29-10 10:51 AM
Quick Reply: wheel spec opinion?
