Old 12-15-14, 01:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Check Engine light with Vsc and trc control light on
Old 01-26-14, 01:05 AM
dannyboy26
dannyboy26's Avatar
Originally Posted by panda08
honestly, just replace the gas cap and when you put the new one on make sure its properly secure. have the code reset afterwards. OEM gas caps don't cost more than 30 dollars probably.
I think this might work and would save you tons of money...
Old 01-26-14, 01:30 AM
awzdusty
awzdusty's Avatar
Thanks for all input! ill probably by a new gas cap just in case. Well i took it to a mechanic and they just did exactly what I did at pepboys except cleared the code and tighten the gas cap -.-. Waste of time.... LOL but so far the check engine light and vsc light and trc light hasn't come on.
But a black cat ran across my path today while i was driving so idk...
Will keep you guys updated
Old 03-11-14, 09:36 PM
Lexusis6nw
Lexusis6nw's Avatar
I have a 2006 is250. Mode F Sport exhaust and F sport intake. Just got the pistol and water pump replace due to code engine misfilre. Replace by lexus in May 2013. So far no issue but I started notice the Check Engine light with Vsc and trc control light on often a lot now. It would turn off for one day and show back up.
Remove the battery positive charge and it disappeared but show up the next day.
Old 03-11-14, 10:46 PM
jasonr
jasonr's Avatar
always start with the cheaper parts. go with a gas cap first if not check the valve. then canister. some shops can't find the vacuum leak. Where do you live in CA?
Old 09-30-14, 10:03 AM
awzdusty
awzdusty's Avatar
Thanks guys for all the input! All I did was replace maf sensor and the CEL disappeared, but just recently I received a p2757 error code. Which is the Torque Converter Clutch Pressure Control Solenoid Control Circuit Performance or Stuck Off.
So do you guys think flushing transmission fluid and cleaning the solenoids/torque converter will help? Or am I still going to accumulate metal flakes regardless....
Old 04-17-20, 05:54 PM
2ndGenIs35
2ndGenIs35's Avatar
What did you end up doing? Literally have the same thing going on now about to buy a TCC Solenoid and attempt to replace but want to see what people say here first
Old 04-20-20, 05:31 PM
07lexis
07lexis's Avatar
I have same thing going on as well rwd is250, just had transmission fluid replaced from the pan and a new gasket, pan cleaned, and new transmission filter installed. 2757 comes up, The dealership says $220 for the part geesh!!!! Has anyone replaced this? If so where did you buy it from and how much was it? Part number 35290-34010
oscar55773
01-17-17 03:24 PM
kaliboy562
03-25-14 05:14 PM
nch2oracer
05-11-10 01:37 PM
chriswins
08-20-09 05:27 PM
Boost_lee
Suspension and Brakes
02-07-08 06:58 PM
Quick Reply: Check Engine light with Vsc and trc control light on
