IS350 low idle after recall
Old 01-21-14, 11:55 AM
Shervin350
Shervin350's Avatar
Unhappy IS350 low idle after recall
How many people out there having this issue?
when the car is in drive, AC & headlights are off the car has low idle u really feel it when you rest your knee by the door, this issue started after i got the recall done. i took in again they said they will clean the Throttle body to fix the issue the issue still present, they also said battery going out so i put in a new battery im still having this issue anyone out there with a solution please share
Old 01-21-14, 11:57 AM
4TehNguyen
4TehNguyen's Avatar
it takes a little while for the car to relearn and adjust. Mine was like that for a little but it went back to normal
Old 01-21-14, 12:00 PM
Shervin350
Shervin350's Avatar
Any idea on how many miles you drove?
Old 01-21-14, 06:32 PM
whitebeast
whitebeast's Avatar
i have that problem as well. Will call my dealership to find out.
Old 01-21-14, 07:54 PM
cr3ativ3x
cr3ativ3x's Avatar
hmm never reallly noticed that... i'll have to see if i have that problem too..
Old 01-22-14, 10:17 AM
embolism
embolism's Avatar
how low an idle are we talking about? Mine is around 500 rpm
I feel like the steering wheel vibrates a bit more than before I took it in but could be just me imagining things...
Old 01-22-14, 12:02 PM
Gville350
Gville350's Avatar
I've had the cam gear recall done, and had zero change to my vehicle's idle or performance in general. Still drops down to ~600rpms @ warm idle.
Old 01-22-14, 12:37 PM
Shervin350
Shervin350's Avatar
Like I said ac and headlight must be off and is at 500 door shaking gets worse when fan comes on
Old 01-22-14, 01:34 PM
onepointon
onepointon's Avatar
There should not be a low idle after the recall. If they unplugged the battery, there is a chance carbon build up on the throttle plate it causing it. Sounds like they tried to address that.
Having not looked at the car, with the a/c and headlights on causing the issue, it sounds like either a weak battery or a low charging alternator.
How many miles have you gone since you had it done?
Old 01-22-14, 02:54 PM
Shervin350
Shervin350's Avatar
600+ miles is also new battery
Old 01-22-14, 03:23 PM
gabelias
gabelias's Avatar
I'm having the same issue. Seems a lot lower than before. Also my mileage seems to be affected. My miles approx has always been right on, and now seems to be losing about 20 miles per tank, are you having the issue as well?
Old 01-22-14, 04:35 PM
Tarrant64
Tarrant64's Avatar
I am getting lower gas mileage but I'm aware that this could happen after some work has been done. On my 2nd tank now, and it's slowly getting better.
Old 01-22-14, 06:37 PM
nosurprise
nosurprise's Avatar
After the recall, everything in my car is normal (mileage is fine; car idles around 600 RPM). Today I notice low idle on my car :/ I was at a stop, then I suddenly feel the car shake; I look at the tachometer and it shows slightly lower than 500 RPM -- it goes up a little then go back down to 500 RPM while the car shakes. It only happened once and didn't happen again at the next stop ... Not sure if it's related to the recall though.
That really makes no sense. Why would a car need to learn to idle?
Old 01-22-14, 08:51 PM
Shervin350
Shervin350's Avatar
Was your head light and ac off, I wish more people would call and complain so we can get to the bottom of this
Old 01-22-14, 11:41 PM
idoke1
idoke1's Avatar
It could a small vacuum leak somewhere in the engine compartment.
Quick Reply: IS350 low idle after recall
