DIY: How To Replace the Water Pump on the IS250
Old 01-24-14, 12:57 PM
  #31
Serifiyah
Serifiyah's Avatar
Originally Posted by lexus-is2
Really? that's worrying. i did this almost a year ago and driven over 10k miles and have not had any other symptoms relating to head gasket, oil is also always clean. Anyone else had similar issues? why shouldnt the coolant overflow and gush out? specially since the coolant will start being pumped causing a pressure and as the cap is open it just comes out
Coolant shouldn't overflow because the coolant system is not pressurized with the cap off. In a normal cooling system, it would just bubble out of the opening. When I worked on my honda prelude, the same thing happened to me. Coolant gushed out as soon as i started the car. Turned out to be a blown head gasket.
But I'm no expert, I just know from past experience. Maybe someone with more experience can chime in on this.
Old 01-24-14, 03:46 PM
  #32
BBBsti LTD
BBBsti LTD's Avatar
Great DYI!
Old 01-26-14, 03:34 PM
  #33
ihazabonar
ihazabonar's Avatar
well done! This was something this forum needed. I just had to tackle this about a month without a DIY.
Old 01-27-14, 09:10 AM
  #34
An2ny
An2ny's Avatar
Other Notes:
1- I agree. However when removing the air in the system, it will bubble up and maybe spill a bit, especially since the water pump is so close to the cap. (I am not an expert either)
2-You definitely have to monitor the coolant level for a few weeks and add coolant if needed.
3-It is a good idea not to reinstall the plastic under tray for a few days/ weeks to make sure that you don’t have any leaks.
4-I already poured 2 gallons of coolant in the system, so you may want to buy 2 gallons when replacing the water pump. (I don’t have any leaks at all)
Old 05-17-14, 09:40 AM
  #35
cookies
cookies's Avatar
Thank you so much!!
I just change my waterpump it was successful thanks to you serifiya...
Old 05-17-14, 02:28 PM
  #36
Serifiyah
Serifiyah's Avatar
Originally Posted by cookies
Thank you so much!!
I'm glad it worked out for ya.
Old 06-25-14, 07:40 AM
  #37
Matap
Matap's Avatar
About to tackle this next weekend. I took in my 07 IS for a 75K maintenance and they came back with a repair estimate for $4K. It included this replacement plus, cv's and struts.
Looks like I got some work to do!!!
Thanks for this write up.
Old 07-07-14, 07:57 PM
  #38
Matap
Matap's Avatar
Just wanted to say thank you to OP for the write up. It went flawless. Thanks
Old 08-06-14, 05:47 PM
  #39
lexus-is2
lexus-is2's Avatar
Also want to say a big thank you to Serifiyah for this excellent guide. I've completed my waterpump change.
One suggestion I would make to reduce amount of waterfall from the water pump when removing, I created a little siphon using clear tubing attached snugly to a lid of a plastic bottle, i then pumped it creating a vacuum which drained quite a bit of fluid from inside the waterpump . I pushed in the open end of the tube through the waterpump output where the big O ring sits, then just waited for as much coolant to drain as possible.
Old 03-23-15, 12:55 AM
  #40
Luciefer
Luciefer's Avatar
Thank you!
I did it yesterday, great manual!
Old 04-04-15, 09:00 AM
  #41
Toxicxk23
Toxicxk23's Avatar
Completely forgot about this awesome write up! I will be doing this this weekend!
Old 04-04-15, 12:17 PM
  #42
toyoman29
toyoman29's Avatar
Nice write up, thanks. I will probably replace my thermostat also when i do the water pump.
Old 05-13-15, 06:43 AM
  #43
Gavs98Z28
Gavs98Z28's Avatar
the water pump on my mom's 08 IS 250 was replaced on Friday. No leaks until last night.
took it back to my mechanic... he replaced the small O ring on the water inlet housing ( the one that came with the Aisin pump was destroyed after he removed it ).
ran the car for 20 minutes, no leaks. drove the car home, checked for leaks - nothing.
the car was turned off and sat for about 25 minutes, NOW signs of a leak.
any ideas ?
Old 05-13-15, 11:14 AM
  #44
srt1
srt1's Avatar
I'm wondering if he torqued the housing down correctly ? I'm just about finished with mine and will look for a couple of days for leaks.
Old 05-13-15, 04:16 PM
  #45
Gavs98Z28
Gavs98Z28's Avatar
I called and made an appt with the dealer that originally "found" the water pump leak.
I explained to the adviser what we did and what to possibly look for.
i will report back.
Quick Reply: DIY: How To Replace the Water Pump on the IS250
