2009 IS350 Power Window Issue
Old 01-10-14, 09:56 AM
MusikMann
MusikMann's Avatar
Unhappy 2009 IS350 Power Window Issue
Hi Folks,
New to this forum and I've searched previous threads to see if I can find some help, but haven't found an exact match for the problem I've encountered.
About a week ago, out of the blue, the driver-side power window control button for my front, passenger window stopped working. The passenger-side power window control button still works and will lower and raise the window, but the driver-side control button won't.
I took it to a Toyota dealership and they said the switch is still getting power so they think it might be the motor on the passenger-side window...that's 1,000 just for the part to replace and, to me, it doesn't make sense that the passenger-side control button is still operating effectively if the motor is the issue.
I saw some threads about resetting the window controls. Do you think that is what is the problem?
Old 01-10-14, 10:56 AM
Gville350
Gville350's Avatar
Using the passenger side window control, with the window already FULLY UP, roll down the window all of the way and hold it there for a few seconds. Then immediately roll up the window and hold for a few seconds. If that doesn't reset that window's control, then there's a larger problem here.
Old 01-10-14, 11:05 AM
elexusparts
Former Sponsor
elexusparts's Avatar
Yes sounds llike a simple initialization is needed. Operate the windows fully up and down from each individual door then they should work from the master again.
Old 01-10-14, 04:35 PM
tex2670
tex2670's Avatar
If this solves the issue, you should NEVER go back to that Toyota dealer.
Old 01-14-14, 06:22 AM
MusikMann
MusikMann's Avatar
Gville350 - you were right! Thanks so much for this extremely valuable advice. So glad I checked here instead of just blinding taking the dealership's advice. Tex2670 - you're spot on. Won't be going to that dealer again.
Thanks again to each of you for your advice.
Old 01-14-14, 01:03 PM
Gville350
Gville350's Avatar
^Glad it helped!
Just an FYI, if you ever have to disconnect the battery in the car, it will reset all of the windows. So what you did for the front passenger side window you'll have to do to ever window in the car. It's called the "express" option.
Old 01-14-14, 07:04 PM
korlexus
korlexus's Avatar
A friend of mine has the same problem and the dealer quoted over a grand which made me freak out.
I've seen some infiniti(nissan)&hyundai cars with that issue and it had something to do with the motor inside the door. Sorry to hear that.
Old 01-19-14, 12:59 AM
08wis250
08wis250's Avatar
manthey really try to take peoples money
cooperww
11-10-18 08:16 AM
UDel
09-03-16 02:07 PM
icepanthar
SC- 1st Gen (1992-2000)
01-06-09 09:57 AM
tjschnei
04-28-07 03:01 PM
sc3dreamz
01-05-07 06:02 AM
Quick Reply: 2009 IS350 Power Window Issue
