is this normal?
Old 01-09-14, 02:37 PM
andy350
andy350's Avatar
Default is this normal?
coolant leaking very very slowly...
is this a normal common problem?
how can i fix this?
Old 01-09-14, 02:45 PM
ross96rt
ross96rt's Avatar
I have the same issue with my 2009 and my mechanic, Toyota/Lexus master mechanic, did a pressure test and found no leaks. He noted that my coolant was low and I noticed that at an idle the heat would blow cold, at higher rpm it blew hot which led me to believe it was low on circulating coolant.
He told me to just watch it and let him know if it continues to eat the coolant.
Old 01-09-14, 04:04 PM
minato
minato's Avatar
water pump gone?
did you check where its leaking from?
Old 01-09-14, 05:22 PM
Gville350
Gville350's Avatar
Leaking in that area is not common; I'd look to have it fixed ASAP.
Cyrus701
11-28-18 10:35 AM
2010ISF
IS F (2008-2014)
03-20-16 10:29 PM
Cthopkinsc
Performance & Maintenance
05-31-15 01:10 PM
billymild
12
04-09-14 11:32 PM
James7
IS F (2008-2014)
09-30-11 08:31 AM
Quick Reply: is this normal?
