Can I put Honda/Acura TSX wheels on an IS250?
I've got a spare set of TSX wheels lying around and was wondering if I could put them on my IS250?
I've seen them on a Camry before so thought maybe they'd fit on a 250?
Depends on which TSX and what yo have done to the car. I haveTSX wheels from my old car and using them with winter tires and they fit well with the 250 calipers, but when I did the 350brake upgrade, it did not fit upfront. need spacers.
I still have them if anyone is interested
The Toyota and Honda do not have the same hub diameters. You need hub adapters. Trust me, I know.
Someone told me:
"They will fit but:
1) The will stick into the guards more and will look kinda funny, and
2) You would be fine with stock wheels, but if you get anything wider, you are going to have issues because the wheel is now 10mm closer to the strut tower. "
Is it best not to use them then because of issue no. 2?
"They will fit but:
Center bore is different. (TSX is 64.1 IS250 is 60.1 therefore you need centering rings)
IS250 AWD offset is 45mm, the TSX is offset is 55mm so it's 10mm closer to the inside. (It will look more sunk in and possibly rub against the suspension)
I hope that helps.
