Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
Old 01-06-15, 04:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Dim Halogen Projector Headlights
Thread Tools Search this Thread
Old 12-17-13, 05:56 PM   #1
valeoray
Trader Score: (0)
valeoray's Avatar
Default Dim Halogen Projector Headlights
I searched but could only find people having issues with HID lights being dim. I found another thread on someone using an HID kit with poor focus.
Anyways, I just bought a used 2011 IS250 AWD a few weeks ago and found the halogen headlights to be very dim. The foreground lighting is almost non-existent.
The headlights are clean and are not hazed. The headlight alignment appears to be good. I assume the bulbs are the original. They are the yellowy colored ones. I checked it 10ft away from the wall. Usually only the bumper of the car ahead of me is lit up. The cutoff on the wall looks good.
The alternator appears to be working because the headlights get brighter when the engine is turned on with the headlights already on.
My wife's Benz with halogen reflectors (H7 55 W) are way bright. We used to have a 2007 Camry with halogen projects (with squirrel finders) which were brighter.
I'm just wondering if everyone who has halogen projector have the same issue, or is it just me.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
valeoray is offline   Reply With Quote
Old 12-17-13, 08:07 PM   #2
Noeh
Trader Score: (3)
Can you post a pic? if there is nothing wrong consider an HID kit.
__________________
2015 Nebula Grey IS350 AWD | F1 Pinnacle | Xpel Ultimate
2009 Truffle Mica IS250 AWD | G-Spiders |Fsport Intake | Fsport Sway Bars | Hüper Optik
Noeh is online now   Reply With Quote
Old 12-18-13, 06:05 AM   #3
valeoray
Trader Score: (0)
valeoray's Avatar
My previous stock Golf halogen reflectors
my current IS250 stock halogen projectors
Parked at the same spot at work. The underground garage is pretty well lit.
Old 12-18-13, 12:28 PM   #4
XenonDepot
ClubLexus HID Kit Sponsor
Trader Score: (10)
XenonDepot's Avatar
KBcarstuff XenonDepot
valeoray: Halogen bulbs do dim over time as well, it may be time for another set of halogen bulbs. Or if you want something that's even brighter, you can go with an HID kit which would be 2-3 times brighter than any standard halogen bulb.
Danny
__________________
ClubLexus SUPER SALE is on now!! - SAVE $$$
AUTHORIZED LEXUS Parts & Accessories VENDOR SINCE 2004 - SHOP WITH CONFIDENCE
XenonDepot is online now   Reply With Quote
Old 12-18-13, 05:42 PM   #5
valeoray
Trader Score: (0)
valeoray's Avatar
The car is only 3 years old with only 43,000km. I don't believe that the halogen bulbs would dim that much.
Old 12-18-13, 06:59 PM   #6
Noeh
Trader Score: (3)
It's hard to tell due to the lighting in the garage, but here is post by another member showing OEM halogens at night before the HID conversion:
http://www.clublexus.com/forums/is-s...6k-beware.html
If your lights are much dimmer compared to the post I linked, I would start with replacing the bulbs with OEM or Philips Vision bulbs
__________________
Old 12-18-13, 08:15 PM   #7
pmanliu
Trader Score: (4)
Your car comes with projectors, why not upgrade to HIDs?
__________________
09IS250 AWD | F-Sport | Takeda | Tein | BBS | Hankook |
Other:10RX350
pmanliu is offline   Reply With Quote
Old 12-19-13, 03:37 AM   #8
valeoray
Trader Score: (0)
valeoray's Avatar
Quote:
I don't want to void any warranties on my car, although I know using a wiring harness with relay should be ok.
Old 12-19-13, 03:38 AM   #9
valeoray
Trader Score: (0)
valeoray's Avatar
My cutoff looks about the same, but I have absolutely no foreground lighting like that. And from a distance the cutoff is not bright (see my pic above)
Old 12-19-13, 08:24 AM   #10
XenonDepot
Trader Score: (10)
XenonDepot's Avatar
To save on cost, I would recommend swapping the bulbs with a new set to see if that makes a difference. You should see a difference if you upgrade to the Philips CrystalVision Ultra Bulbs or the Osram Nightbreaker Plus Halogen Bulbs as they are rated to be brighter than the standard OEM halogen bulbs.
And if you think you still need more lighting you can always get an HID kit, they would be plug and play and you can take them out at any time.
Danny
__________________
Old 12-19-13, 09:54 AM   #11
valeoray
Trader Score: (0)
valeoray's Avatar
I've ordered the new Osram Breaker Unlimited bulbs and will post a new shot at work.
I guess halogen projects are not as efficient since 1/2 the light is blocked off whereas with a halogen reflector, almost all the light is reflected down on the road, albeit, not as focused.
Old 12-19-13, 09:56 AM   #12
XenonDepot
Trader Score: (10)
XenonDepot's Avatar
Awesome, hopefully this resolves the light output.
Danny
__________________
Old 12-19-13, 10:03 AM   #13
valeoray
Trader Score: (0)
valeoray's Avatar
Thanks Danny!
Also, anyone with halogen projects care to comment on whether their lights are sufficient, or post cutoff shots? I know the camera settings would be different, but..
Old 12-19-13, 03:41 PM   #14
Noeh
Trader Score: (3)
If your problem persists with the new bulbs, take it to the dealer since you are still under warranty. Also high output halogen bulbs burn hotter and whiter, thus have shorter life than OEM bulbs.
Old 01-08-14, 06:49 AM   #15
valeoray
Trader Score: (0)
valeoray's Avatar
As promised, here is a pic with the Osram nighbreaker unlimited. My dash cam pic came out dark, so I took a pic with my BlackBerry. I know it won't be under the same camera settings, but
Click the image to open in full size.[/URL]y
Similar Threads
Thread Thread Starter Forum Replies Last Post
halogen vs hid mnedescu ES350 (2007 - 2012) 2 11-04-13 11:10 AM
RX300 Headlight Bulb replacement Nickv RX - First Generation 2 10-29-13 03:43 PM
Need Pic: HID In OEM Projectors TheAzn SC 400/300 4 05-21-13 05:36 PM
Another HID Question IS-Jim IS - Second Generation 2 02-17-07 01:00 AM
projectors for GS? bLingIn3o0 Lighting 9 02-07-04 01:39 AM
Tags
97, dim, es300, halogen, headlight, headlights, is250, lexus, projector, projectors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
